Question about T-Mobile Sidekick II
How to fix my sidekick two camera
My camera does not work it sey's it is low on memory what do i have to do to fix it
Flip open your sidekick 2 screen then launch the camera. it will re-init the camera and it will function again
--xelderon.com--
Posted on Jun 18, 2008
Turns off itself
Please check the batteries and the battery contacts. Also the contact points in the camera. Most digital cameras will shut themselves down, when the battery voltage becomes to low. Just to protect the camera and the memory. If it tries to access the memory, while the voltage is to low, it could damage the pictures already taken.
Please also check if there is not any obstruction for the lens. So it can come out of the body freely.
Dec 18, 2013 | Kodak EasyShare P850 Digital Camera
It's did not take memary card. it's sey's format the memary. I reformat memary but same problem and after chenge new memary displyed same problem. it's can fix??
The 4GB card is an SDHC card and will not work in the 735. The 2GB card should format in the camera. Make sure it's not write-protected. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 28, 2012 | HP Photosmart 735 Digital Camera
What do i sey my dmc-ft3 on for record quality
That's up to you. That's why they give YOU the choice.
If all you're going to do with the pictures are to post them on the web and/or email them to friends, choose a small size and Standard quality. If there's a chance you might want to print some of them, choose the largest size and the Fine quality.
There is a trade-off between picture size/quality and memory space, but at the current prices this shouldn't be a major factor. Unless you're going on a long trip without additional memory cards, it shouldn't matter whether your memory card can hold three hundred or five hundred pictures.
Jul 28, 2012 | Panasonic Lumix Dmc-ft3 Waterproof Digital...
I have DMC-LZ8. I have relaced WITH NI-MH R6/AA RECHARGABLE, 2900 BATERRY, still it says low baterrey after 2 or 3 snaps. What do I do?
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 14, 2011 | Panasonic Lumix DMC-LZ8K Digital Camera
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
My camera seys it's recording but nothing comes up
Head down to Walmart and pickup a JVC head cleaner. Be sure to follow the directions on the package. Also, change the brands of tapes that your using to either Panasonic, JVC or Fuji brand- or the professional versions of ANY brand. Something else: Only re-record on any one tape to a maximum of three times, with only ONCE being recommended.
Jan 22, 2010 | Canon GL2 Mini DV Digital Camcorder
Memory Stick Error
If you are receiving C 1301 Error Memory stick error.
First clean the contacts on the memory stick with a pencil eraser Reinstall if no check the slot in the camera for debris paper etc... blow it out with a can of air If no Reset the camera with the button below the mem stick housing it says reset, use a paper clip if no cycle the camera by removing the battery and turn on and off If no and seriously here turn the camera on with the memory stick installed tap the camera into the palm of your hand give it a light jolt on all four sides cycle the on off of the camera between taps. Wacky but it will clear this error code.
May 26, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
CAMRA
you have jammed the 3 lens studs outside of the track , you cannot fix it without dissembling the entire camera to the lens,
its best to leave it alone and sell it on ebay for the lcd is worth 35 to 60
Apr 13, 2008 | Cameras
Memory Card Errors with Canon PowerShot S3
There most definitely is a solution to this problem. Follow this link for a step by step fix for the memory card error. It requires taking the camera apart but if the warranty is expired you have nothing to lose. Fix worked fine for me.
http://willj.net/2006/02/12/fixing-the-memory-card-error-on-the-canon-ixus-400s3/
Nov 22, 2007 | Canon PowerShot S3 IS Digital Camera
T-Mobile Sidekick II Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
