Question about Swisher Garden
The rear torsion welderment that control the deck lift on a swisher ZT 2250 zero turn mower broke on one side of the mower, the entire bar sells for $124.00. Wouldn't it be quicker and easier to have it welded back or would I run into problems?
  • Anonymous Mar 31, 2014
    FOWARD SPEED TOO SLOW
  • 472 Answers
I WOULD WELD IT OR IF YOU HAVE A PART # FOR IT ILL TRY TO GET YA ONE CHEPER I MAY HAVE A USED ONE
Posted on Aug 22, 2010
Hitch pin clip broke that holds up mower deck. Mower deck about 1/2 inch shorter on one side. Rod to hold mower deck to frame will not stay flush when I try to tighten bolt to raise deck
YOUL NEED TO REPLACE THE ENTIER HICH PIN SYSTEM THE BITS MIGHT BE COASTLY THOUGH SORRY ITS TOO SHORT TO ALINGE NOW NO WAY YOU COULD REATACH THE DECK SAFETLY UNLESS YOU GETVA QUalified welder to manufaturecyou a knew which PIN bit and a fix it etcetera.
Aug 02, 2015 | Husqvarna RZ4219 42 inch 19.5 HP Briggs &...
Deck belt diagram
Contact Swisher to request a diagram.
Apr 06, 2014 | Swisher Ride King Zero Turn Mower 23 Hp,...
Wiring diagram for 1958 Swisher Ride King Riding Mower
need wiring diagram for 1958 swisher ride king riding mower. need picture of mower
Dec 10, 2012 | Swisher Ride King Zero Turn Mower 23 Hp,...
Mower is the Swisher ZT 2660 runs great. Blades slow then stop during cutting, I changed belts (drive & deck). Last year you advised it maybe the electric clutch. Question is that a do it yourself...
I have this mower and had this same problem. It turned out the bolts holding the motor to frame backed out and were allowing the motor to tilt, and then the belts would slip and burn up. Check all motor bolts for tight, and if not tight change bolts and lock washers. Lock washers were not originally on these mowers.
May 01, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Broke engine to deck belt after only 33 hours of mowing. Swisher needs to resolve this problem. Will they stand behind their products?
I also had the same problem, belts kept breaking after a short period of time, and the problem turned out to be the four bolts holding the engine to the frame loosened to the point the engine was tilting and letting the belt slip. Once new bolts with lock washers were installed, all has been good.
Sep 19, 2010 | Swisher Zt2350 Zero Turn Radius Tractor
My swisher zt blows the fuse every time i engage the blades...can get the engine to run and drive. problem is only when i start the blades. any ideas?
Check the all wiring from the engage blade button back to the electric clutch for worn spots that may be grounding out on the frame.
Sep 17, 2010 | Swisher Zt2560 Zero Turn Radius 60" Riding...
I have a swisher ride king mower that keeps shredding belt from moter to deck. dose anyone have solution?
I have been told if the parking brake is engaged and you try to drive the mower it will instantly put a burn spot on the belt. I hope this helps.
Aug 11, 2010 | Swisher Ride King Zero Turn Mower 23 Hp,...
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Deck plugs up, will not discharge, especially in taller grass, tried different blades nothing works.
the one thing I have noticed with my swisher 60" is my grass have to be dry or the deck will clog and because of the mulching deck it is not recommended to cut tall grass.
Dec 26, 2009 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Garden Logo
106 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
