Question about NetGear WGR614 Wireless Router
Wireless connection of netgear wireless router for compaq laptop
Hi!
it seems that my laptop c767tu is ahving a problem connecting to netgear wireless router. my laptop can detect the wireless connection but i cant log in even though my connection is "unsecured" (no password). im running windows vista on my laptop. the wireless router is wired on my desktop running windows xp.
hope you could help me with this.
thanks in advance.
  • monch31 May 05, 2008
    accdg 2 d box, it works with vista...
    Sergeant:
    Champion:
  • 427 Answers
When you look on the box that the router came in, you have to look to see what Operating Systems it is compatible with. In many cases, routers will not be compatible with vista. I have a Linksys WRT300N, and it works great with Vista.Hope this helps.
Posted on May 04, 2008
I have a compaq presario r4000 will no longer connect to wireless after installing a netgear router
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID and Encryptionkey.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Mar 07, 2012 | HP Compaq Presario R4000 Notebook
The internet in my CompaQ works fine, but i cannot seem to get it to connect to a Dell laptop.
It must be the wireless settings on your Dell. Go to wireless network settings and add manually the wireless profile for your wireless network
Jun 14, 2009 | NetGear WGR614 Wireless Router
Can't connect to netgear wnr 2000
conect to netgear then shut down and turn it back on.
May 27, 2009 | Acer TravelMate 5520 Notebook
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
NO WIRELESS NETWORK ADAPTER
I have just checked the specs of your laptop and it says that these come standard with a wireless network card.
What problem are you having in regards to wireless?
Some laptops have a switch (generally on the front or sides) that needs to be activated before the wireless card is "enabled" in the operating system. You will need to refer to the owners manual for the location of this switch.
Jan 12, 2009 | Compaq Presario 700 470024-192 Notebook
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
Sometimes firewalls on your computers can cause connection issues. I had the same problem with my home network. I had norton internet security 2008 on both systems, but the firewall settings on both computers had to be adjusted to allow the computers to talk. If you have different brand firewalls on each computer, you should consider to switching one of the computers so that it matches the other.
Another thing you want to do is log into the router's web utility and check to see if the wireless settings are blocking wireless connections in some way. You also want to make sure the ssid broadcast is enabled.
Finally, you really should consider using security on your router, so wireless connections would be password protected. I suggest wpa personal.
May 03, 2008 | NetGear WGR614 Wireless Router
NETGEAR wgr614 cable wireless router
have you tried to follow the manual chapter 3, page 3-1 ?
If you lost your manual you can find one here:
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
One of your computers can go online because its using a wired connection to the router, but the wireless clients cannot access the connection - is this right?
Then you only need to setup the wireless part in the router.
Mar 07, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
WiFi not recognized on Compaq laptop
this can happen sometimes, just go to network connections in control panel, right click on the wireless icon and click dissable (or press the rellevant button on your notebook) Restart pc and then right click on the icon again and select enable. There should be an icon in your taskbar, right click and select view network connections, and then see if your router is listed and click connect.
Sep 25, 2007 | NetGear WGU624 Router
NetGear WGR614 Wireless Router Logo
150 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
