We are looking for the fault code f1 on our gloworm 30HXi boiler do you know what it is
  • Heating & Co... Master
  • 2,463 Answers
Igniton code no gas detected
Posted on Aug 22, 2010
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
What does it mean when PO8 and H7 are flashing on worcester boiler dial
Either on the inside of the door or in your manual will have a list of all the codes. You could try turning the unit off, not while its in operation, and turn back on in 20 seconds. But first find the meaning of the codes, or faults. They will be listed. Unless the code is stupid simple, contact a pro. CO and fires kill if you don't know what you're doing
May 12, 2014 | Heating & Cooling
How do I use the analogue glide down timer
1) Copy following link for setting analog timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/pdf/Glowworm-flexcom-analog-timer-manual.pdf
2) Add a comment Dec 2012 for additional information.
Dec 12, 2012 | Hardware & Accessories
Glowworm 24hxi combi boiler fault codes
it's an ignition fault (lockout) failed to light.
cause:
no gas
insufficient gas
incorrect gas valve adjustment
electrode ignition lead defective
electric igniter defective
check air inlet duct
check connections to igniter unit.
most common cause is igniter is defective (looks like a spark plug)
if you can hear a clicking when boiler goes to ignite, then it will be igniter at fault (no spark), check lead going to igniter (for any deterioration, looks like a ht lead). if all ok. change igniter.
hope this helps?
Jan 22, 2012 | Kitchen Ranges
Hetline sargon boiler manuals
my heatline sargon 35kw boiler is showing f1 fault i have drained boiler and cleaned out relivant peaces but still no change any advice in sorting this out
Dec 20, 2010 | Heating & Cooling
My gloworm 30cx boiler keeps showing fault f1, what does it mean ?
Low gas pressure or flow: make sure you have gas to the unit.
Dec 19, 2010 | General Heating & Cooling
Valliant combi boiler Fault Code F1 What does it mean
f1 means failed to fire check you have gas to bolirt and check water leval on boiler 1.5 bar
Aug 09, 2010 | Heating & Cooling
Gas boiler cuts out after about 60 seconds
It may be fixable but any work done on any gas appliance must be done by a properly qualified person and in the UK must be Gas Safe registered. I am not nor do I claim to be so registered, this is for information only.
Jul 03, 2017 | Uniflame 200209 Open Flame Patio Heater
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Heating & Cooling Logo
176 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
