Toshiba 23" LCD/Dvd model#23HLV87 making loud crackle noise when turned on.Will not shut off unless power is disconnected.
  • ababslee Aug 22, 2010
    Do you think it can be repaired reasonably or should I toss it?
  • 5,138 Answers
Look on power supply board for bad capacitors they will be vented or puffed up on Top 1000uf 16v 220uf 10v, 330uf 10v
Posted on Aug 23, 2010
  • 11,800 Answers
Loud noises = discharges inside it, more precisely in the power source. Since sparks are never a good sign when inside an electronic device, you should stop using it and take it to a repair shop ASAP.
Posted on Aug 22, 2010
  • Azrael SRL Aug 22, 2010
    Since it was still working then the damages are still limited so the bill for its repair will be reasonably small.
    Thank you for your fast response,I will try a repair service.
Changed the main board in my Toshiba 23HLV87, the green light comes on but no picture or sound nor will the green light go out when pushing the power button
I would investigate the T-con board (Timing control board). If you do not have sound or video as you say, it may be the T-con board that will need replaced.
Oct 05, 2013 | Toshiba 23HLV87 23 in. LCD Television
Game mode won't turn off
simply change the channel and it sets it back to TV mode
Aug 17, 2012 | Toshiba 23HLV87 23 in. LCD Television
I have a 23'' toshiba 23hlv87 lcd television and the screen is remaining blank after turning it on, could you tell me what is wrong with it?
Good day!!!
That problem is happen when your inverter board is defective please replaced it..
With the same range,type and value..
Thank you!!
Jul 11, 2011 | Toshiba 23HLV87 23 in. LCD Television
Our Toshiba 23HLV87 combo TV won't eject the DVD. We've had the TV 2.5 years and about a year ago, this problem would occasionally happen. Eventually we could get the disk to come out with patience and...
Hello Friend,
A small belt that connects the motor and the DVD tray is worn out or lost its elasticity, ask your nearest authorized service provider to visit and replace it.
Good Luck.
Dec 20, 2010 | Toshiba 23HLV87 23 in. LCD Television
Is there a reset button on the Toshiba 23HLV87 models? There was a poweroutage and when we returned the tv would no longr turn on it just makes a clicking sound and the red power light clicks on and off....
There is no reset button, try disconnecting it from the wall outlet for about an hour to let it reset itself. The EPROM may have been scrambled when the power comes back on which usually produce high voltage spikes and sag since everything that are plugged in will try to turn at the same time.
If it still does not work, you will have to open it up and do some inspections.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 21, 2010 | Toshiba 23HLV87 23 in. LCD Television
Picture looks like brightness was turned 100%, very white looking
Last 3 years, you are lucky. It sounds like you are having the problem with either the T-CON board or the main logic board. Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=Toshiba+23HLV87+
Send me picture so I can see what you are talking about, budmrtn@aol.com
If you are going to DIY and have proper tools and know safety precaution then please read on:
Jun 29, 2010 | Toshiba 23HLV87 23 in. LCD Television
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
23 inch diagonal tv/dvd combination model # 23hlv87
with comcast red ok select switch 11256, 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast grey ok select switch 0154, 0156, 0060
May 20, 2008 | Toshiba 23HLV87 23 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
