Question about NRS Hoveround MPV 5 - Used Power Wheelchair
Put in drive controller just blinks - NRS Hoveround MPV 5 - Used Power Wheelchair
Make sure the release levers are up all the way (in front - above the footplate). Shut power off and try chair again. If the entire row of battery lights on the joystick controller are still flashing, you need a new joystick. Contact Hoveround or The Aftermarket Group online who will qoute you a repair cost. It will probably run anywhere from 300 to 1100.
Posted on Aug 27, 2010
The western digital T2 keeps blinking.
what blinks , be precise?
what part number drive, 1000 made.
what system is it IN.
what OS?
is this really a relic 2.5" laptop T2 drive
or did you mean a new 2TB drive SATA?
is it sata or Pata ? drive.? the p/n will tell me that.
all drives blink for activity. but that is with eye, looking at it, directly.
some controlers blink
some MOBO blink for same.
Oct 04, 2013 | Western Digital Computers & Internet
Ive been using my iomega eGo external hard drive for a couple years now. Today, it wont show up when i plug it into my laptop. The LED is blinking, albeit in a very random rhythm. Any suggestions?
These are some of the most robust external drives available. But, everything breaks. The most likely cause is a failed controller in the case. Remove the drive and put it into a new case.
Apr 15, 2013 | Iomega Ego Computers & Internet
2000 tundra 4wd takes forever to engage, 4 low will not
try pushing button and then put in reverse back up a bit and then put in drive see if it goes in quicker. put truck in nuetral befor putting into 4 low
Oct 01, 2012 | Cars & Trucks
Gear light in Drive started to blink while was driving
This light is warning you that a fault has been detected in the electronically controlled transmission by the Transmission control module. You must get the system scanned for the fault code that was set in the modules memory when the light was turned on.
Jun 11, 2012 | 2003 Honda Pilot
My pen drive is blinking when i connected to my system and my pendrive is kingstone 4gb what i shoud do now it was not opening now
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps you
Apr 14, 2012 | Kingston Digital 4GB DATATRAVELER C10...
My seagate freeagent 1tb is blinking whit lights and my computer does not recognize it. Help me
***Please NOTE***
Touch the drive and put your ear to it, to test if the drive is spinning and working. Do this while it is powered on. Also, try disconnecting the USB cable, reboot the computer, re-connect USB cable to another USB port on computer. If you still have the same issue, try the below solutions.
  • Make sure the computer and external hard drive are powered on.
  • Disconnect the external drive's USB or the eSATA cable, which ever one you're using.
  • Disconnect the power supply plug from the external drive.
  • Power off the computer.
  • Disconnect the computer's power supply cord for 60 seconds.
  • Reconnect the computer.
  • Power on the computer.
  • Connect the power supply to the external drive.
  • Connect the drive's USB or the eSATA cable and check for detection.
If the still no detection and still blinking lights on the drive, check the power supply to the drive.
Check to see what the led light on the power supply is doing.
If it's blinking, power down the drive, unplug data cable and then reconnect the power supply to another electrical outlet. If it still blinks repeatedly, then you power supply is bad.
If the led is solid (lit and not blinking) follow the same steps from above to connect it to another outlet.
Next, plug the power supply to the external drive and power it up.
If the power supply starts to blink repeatedly, then your controller board inside the enclosure is bad.
Thank you for the opportunity to help you.
Jun 04, 2011 | Seagate FreeAgent Pro 1TB External USB...
After washing Rinse cycle will not work the washer stops and it just hummms when it gets to the rinse cycle you can manuall put it to the spin cycle and it works but the washer will not move once it gets...
You probably have a broken drive coupling.1091b32.jpg A very simple repair. What you do is flip up the controls and pop the clips, remove the lid switch connection and get that case out the way. 85c73c9.jpg5464918.jpg003967e.jpgYou can then go after the drive coupler.b6901a4.jpg Remove the pump and motor and inspect the coupling for breakage.
More here, Much more here at my Forum
A repair guide for you sir: Direct drive service pamplet
Jun 06, 2010 | Kenmore 22422 Top Load Washer
My new u-control helicopter is experencing spinning
how much is it spinning after and if not to much adjust the st. trim on the controller.
Aug 06, 2009 | Shuttle 9094 Emax Remote Control...
2005 pathfuinder - climate control display blinks
Could be a number of things, usually a blinking screen indicates that the climate control module is defective. But not always, If one of the vent doors jammed of a solenoid for one of the doors malfunctioned It would cause the screen to flash.
Apr 26, 2009 | 2005 Nissan Pathfinder
Blinking dashboard drive light
The light is blinking to let u know that an electronic failure has occured in the transmission, u may feel nothing wrong or it could fail next week, get it tested for the trouble code that is stored in the trans computer control module.
Dec 10, 2008 | 1995 Honda Odyssey
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
90 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
