Question about Sony Playstation 3 (PS3) Console
Error 8002A221 displays on screen when I try to play on-line
On display many line showing, cutting a effect of game can you help me to solve a problem or i have to replace a display or i have replace a display can you give me the address, give me near colaba
To find out if you need a new screen for your laptop try plugging in an external montior. If it works with no lines then the video is good and the screen is the problem. If it has the same lines then you have a video card or video driver error.
If it is the card or driver then reinstall the drivers and try again.
May 12, 2011 | Computers & Internet
D200B DVD player. It's nearly new but two solid green bars have appeared horizontally at top of screen when playing DVD's. One goes all the way across and the other halfway. When I push set-up button,...
this is either a video driver error caused by out of date drivers or trying to display something your computer does not have the capacity for if you meet the min system requirements and your drivers are up to date try displaying other programs to make sure that you find the same lines if after updating drivers you still have lines either the monitor or graphics card has burnt out
Oct 25, 2010 | GPX PD808B Portable DVD Player with Screen
The screen went black and now it has alot of lines across it
Sounds like a bad video card.A video inverter could cause distorted graphics but usually it turns out to be the graphics card.
Jul 30, 2009 | Computers & Internet
Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
May 12, 2009 | Sony Walkman Video NWZ-S618F MP3 Player
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
Blue Screen
Please clean the Head with a Head cleaning Cassette and try again
Oct 14, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Each time i press play on a song,the screen says 'FORMAT ERROR'
Check the fomat of the song you are trying to play.
Check what are all the formats it can play.
And try playing them using the player compatible file formats.
Good Luck.
Live, Love, Laugh.
May 13, 2008 | Sony Walkman Bean NW-E305 MP3 Player
Displays lines then freezer
might be games software problem so plz reinstall games software or try another game (if particular game issue is there )or consult nokia care centre
2.(alternate) might be display problem
Feb 06, 2007 | Nokia 3230
Sony Playstation 3 (PS3) Console Logo
153 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
