source: http://support.2wire.com (please visit!)
The Xbox Live service is compatible with
all current and previously shipped versions of 2wire software.
Simply connect your Xbox unit to the 2wire network and log on to
the Xbox Live service.
If you are experiencing problems
connecting to the XBox Live service, follow the troubleshooting
procedures provided in your XBox Live documentation or XBox Live CD
sleeve.
If you continue to have trouble, here are some additional troubleshooting tips:
1. Reconnect your Xbox to the 2wire Homeportal
Turn off the Xbox and unplug your 2wire HomePortal from the electrical outlet.
Connect one end of an Ethernet cable to the Local Ethernet port on the 2wire HomePortal.
Connect the other end of the Ethernet cable to the Ethernet port on the back of the Xbox console.
Plug your 2wire back into the electrical outlet and wait for all lights to turn solid green before proceeding.
Turn on your Xbox console (without a disc in the tray).
From the Xbox Dashboard, choose Xbox Live.
In the network settings, test the connection. The connection test should pass.
2. Create custom 2wire Homeportal firewall settings
Although a custom firewall setting should
not be required, manually configuring your 2wire firewall ensures
that it is not preventing your connection to the Xbox Live service.
HomePortal software version 3.x
From your computer, open a browser and type: http://homeportal into the address line to access your 2wire configuration pages. Alternately, you can type:
http://gateway.2wire.net
Under the list of Connected Devices you should see a device labeled "unknown device". This is the Xbox unit.
Click on "View your home network" link in the same box.
Click on "Edit firewall settings" next to the unknown device.
In the lower left-hand corner of this screen, click on "Add a new user-defined application."
Enter "Xbox Live" for the Application Name.
Select Protocol "TCP".
In the port "From:" and "To:" boxes enter 53. Do not change the other settings.
Click on Add.
Repeat these same steps for the following ports and protocols:
Port Protocol
53 UDP
88 TCP
88 UDP
3074 TCP
3074 UDP
Click on "Done" in the lower right corner.
Under "Select a Host Computer" select the "unknown device".
Under "Select the Application(s)" click on "User-defined."
Select "Xbox Live" in the box on the left and click "Add."
HomePortal software version 2.x From your computer, open a browser and type:
Click on the "HomePortal Upgrades"
button and if you have an upgrade available, download the upgrade. If
you do not have an upgrade available, continue to next step
Click on "Advanced" link in the same box.
In the lower, left-hand corner of this screen click on "Add an application" link. Enter "Xbox 1" for the application Name.
Leave the Protocol setting as "Other".
Click on DONE on the "Add Application" page.
Repeat the same steps for the following ports and protocols. You will need to create a new name for each entry:
Xbox 1 53 UDP
Xbox 2 88 TCP
Xbox 3 88 UDP
Xbox 4 3704 TCP
Xbox 5 3704 UDP
Click on DONE on the "Hosted Application" page when you are finished creating the list above.
