Question about HP Office Equipment & Supplies
The computer is not recognizing the printer - HP Office Equipment & Supplies
    Scholar:
  • 122 Answers
Find out what model HP printer you have and download the drivers. Install them, and reset the computer "IF" windows does not find the printer before hand.
Posted on Aug 22, 2010
My computer does not recognize my printer
Follow steps strictly as directed by instructions. It should recognize the printer!
Feb 11, 2015 | Kodak ESP Office 6150 All-in-One Printer
I am unable to set MX90 as a printer. It is not shown me the option when I go to Roland MetanzaStudio menu -set up the printer- Please help
I found this online....hope it helps...
========================== How do I get computer to recognize printer? You have a problem. Your computer does not recognize the printer. Moreover, you cannot reinstall the printer driver or software because you have misplaced the CD. Well, don't worry. The steps given below will help you out.
STEP 1: Checking the Cable and Power Supply
The simplest step comes first. Just check whether the printer cable is connected to the computer securely. Moreover, also check whether the printer power cord has been plugged in properly.
STEP 2: Uninstall Old Printer Software, If any
If you have had an older printer, then make sure that printer drivers and software are uninstalled from the computer. If you don't, the computer might not recognize the new printer. This problem is common in inkjet printers.
STEP 3: The Paper Size
A simple matter like the incorrect selection of paper might also lead to this problem. If the printer paper size does not match the size set in the printer settings, than the computer might not recognize the printer.
STEP 4: Restart
There are times when all it requires is to restart the computer. This is in case where you have connected the printer after loading the driver. If this is the case, then just restart your computer.
STEP 5: No Pass through Device
This is actually an extension of your first step. Make sure that the printer cable has a direct connection to the computer. No pass through devices must be used for this purpose.
This Article is written by John C Arkin.
Dec 12, 2014 | Roland Metaza MPX-90 Metal Photo Impact...
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
My computer wont recognize my printer/scanner
Try another USB Printer Cable, that noramlly solves the problem,, if it still doesn't recognize it then you must send it in to check the Mainboard of the printer which will also cause the problem
Have fun
Cheers
Apr 21, 2009 | Samsung SCX-4100 All-In-One Laser Printer
My computer with Windows Vista doesn't recognize the Lexmark X125
http://downloads.lexmark.com/perl/downloads/downloads.cgi
The link above is the driver for that printer. Download that driver and then install it. Once you install it, the computer should recognize it.
Mar 26, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Computer won't recognize printer
Same for me. Did you find a solution to your printer ?
Dec 20, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
20 people viewed this question
Seeker5211
Seeker5211
