Question about Curtis-Mathis Televison & Video
The volume on my television keeps going down by itself. I have a picture on the screen but no sound
  • 901 Answers
Audio circuit is not getting supply voltage. Dry solder, weak capacitor could lead to this problem.
Check the audio IC no and search in Google. Check the Vcc, Vss, Vdd pins and check the voltages. Trouble shoot accordingly. Check speaker capacitors also .
Posted on Aug 22, 2010
I was using my remote to change channels and hit the volume control before the channel was on the screen. Now my television has no picture or sound and keeps turning itself off and on.
I would pull the power cord on the television and leave it for 5 minutes before plugging it back in. It should solve the problem. If it doesn't, pull the batteries out of the remote, and wait 5 minutes before putting them back in.
Good luck,
Paul
Dec 27, 2016 | Televison & Video
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
Apr 21, 2011 | Memorex MLT1921 19 in. LCD TV
Sound but no Picture.
You have an akb shut down due to bad crt's (it could be any one of the crt's bad).
Mar 19, 2010 | Sony KP-46WT520 46" Rear Projection...
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Philips tv
it seems that there is a problem in your sound section. it seems that there is no proper supply to sound section or some capacitor might be faulty.
Sep 24, 2007 | Philips 32PW6506 32" TV
SOUND BUT NO PICTURE
I HAVE A PROBLEM ON SHARP 21 INCHES THE PROBLEM IS NO VIDEO BUT THERE WAS A SOUND IF I PUSH THE CHANNEL UP AND DOWN WILL DISPLAY OR VOLUME OK BUT NO DISPLAY BLACK SREEN
Aug 26, 2007 | Sony KV-36XBR400 36" TV
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Televison & Video Logo
60 people viewed this question
Top Curtis-Mathis Televison & Video Experts
matt martin
matt martin
Stan Skaggs
Stan Skaggs
Are you a Curtis-Mathis Televison and Video Expert? Answer questions, earn points and help others
