Question about Western Digital NetCenter WDXE3200JBN 320 GB Network Hard Drive
I have a Western Digital 500Gb network HDD (WD5000B019). It has been stored away for a while and I've just recently set it up again, as part of my network. Long story short,I have misplaced the power adapter for this HDD. Can anyone confirm what the direct current output is supposed to be for the adaptor associated with WD5000B019? I have several spare 12V 2.0A and 1.5A ones, but I know some older WD HDDs had 2.5A or 3.0A?
calanan
SOURCE: Need to open WD MyBook 1TB HDD model WD10000H1CS-00
I have this same problem and found a great write-up here that has text and photos of the process. I haven't tried the process with mine but there are plenty of responses to his posting indicating success. Good luck.
- mike
Posted on Dec 10, 2008
  • 5 Answers
SOURCE: Western Digital 500GB My Book Essential won't start up
To save your data from a bad Wd Ebook you need to download UBUNTU and burn it to a cd. Boot from the cd. Do not install Ubuntu just click try it out. When it loads turn on your Ebook and iit should appear on the desktop. If not click the places tab on top and find it there. Right click the EBook and mount it. Now you have access to all the data on the ebook. Iy yoou have enugh space n your cpu hard drive save it there, if not you will need another surce large enought to copy the data to.. I have used this method to save many hard drives, flash drive and other unreadable media. if the drive is totally toast you are out of luck but this method works moost of the time. Any questions drop me an email.
Shayne
Posted on May 01, 2009
miokitty
  • 17 Answers
SOURCE: cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
Posted on Sep 18, 2009
SOURCE: Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Posted on Nov 18, 2009
SOURCE: how unlock the wd smartware my passport
forgot my password
Posted on Jul 31, 2010
How to set up system to be able to see cameras away from home?
With the RJ-45 Connection, up to 5 users can simultaneously monitor remotely from anywhere through LAN or Internet. do you have it set up this way?
Nov 30, 2014 | Digital Peripheral Solutions 8-Channel...
Western Digital HDD WD5000AAKX reads slow..
What do you mean by slow? Compared to an SSD the HDD would obviously be slower. If you're running your OS and everything off that HDD, try defragmenting it. Please run benchmark tests (e.g. Crystal Mark) and tell me the results you get! Typically you should get 120MB/s for your type of hard drive.
Nov 03, 2012 | Western Digital HDD WD5000AAKX 500GB SATA...
Wd5000AAkX no jumper diagram need to put it as a slave
There are normally no jumper settings on a SATA HDD as you can only connect one drive per SATA port, hence every drive is a Master on its own port.
You can set Boot Priority within the BIOS settings if you have more than one drive attached.
Dec 13, 2011 | Western Digital HDD WD5000AAKX 500GB SATA...
Losing network connection on WD
if there you can connect via usb cable try to observe if detection lost, if connection still freeze the problem most likely in hdd. but if work fine may be in network connection related check for patch chord possible lost connection.
Apr 07, 2010 | Western Digital 500GB My Book World...
Not recognized
A Network Drive, that which is connected via an Ethernet cable will not appear as new hardware. You should have connected it to the router on your network, then seen it as a network device.
Check My Network Places.
You will need to Map a drive to see it every time you boot.
Nov 29, 2009 | Western Digital 500GB My Book World...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
WD Hard Drive Not Detecting
Yes, this can be done via the user web interface, by typing in mybookworld or wdstorage into the web browser and the shared storage manager should come up. If you go to general setup there should be an option to update network settings.
Oct 31, 2008 | Western Digital 500GB My Book World...
WD5000aaks western digital 500GB HDD motor not spining,
Try reseating the power connector for the drive. You can try another unused connector if it will reach. Do the same for the data cable. Reseat both ends of the cable a couple of times to shine up the contacts. If none of this works, then a data recovery service will be needed.
Jul 14, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
Western Digital NetCenter WDXE3200JBN 320 GB Network Hard Drive Logo
179 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
