Question about RCA DISH Network(r) 311 Satellite System
I am replacing a 50' run of RG-6 Quad Shield cable from my central box in a closet to a wall jack. I am simply unplugging the current run because the jack is in the wrong place and replacing that run with a new one. I'm not using any splitters or anything fancy - just replacing the current run. I have tried two different cables and neither one works. I hook up the old run and all works fine. Hook up the new run, and nothing works. The system "searches" for a signal and will all day, I suspect. I take my new cable and attach it to the wall jack of the old run, and it works great. If I bypass the old run and go directly to the box with my new cable - nothing works. Any ideas as to why?
    New Friend:
Hello, I am a Dish Network technician.
The most likely reason you're having this issue is may be some type of switch between your closet and your TV jack, that you're bypassing when you install the 50' lead. Your best bet will be to schedule a technician to come for a visit, we have the tools and training needed to find and eliminate your issues with ease. Most likely, this is something that the average person won't be able to tackle.
Posted on Jun 16, 2015
5 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Posted on Oct 01, 2007
  • 6 Answers
SOURCE: RCA DRD485RG Direct TV
verify that the problem box is not looking at a "favorite" list
Posted on Jan 13, 2008
ramon49
  • 111 Answers
SOURCE: Sat signal reaches only 1 cable outlet
you need to split the line at the receiver box. The signal from the Dish needs 18vdc to the receiver or you'll get NADA.. If I understand you correctly???
Posted on Mar 08, 2009
SOURCE: Used receiver at different location for 3 months.
Had repair man come. The coax connection going to TV from receiver had went bad in the receiver. The other connectors in box worked but not the coax anymore that is why the box worked on other TV since using video and sound cables. Got new box for signing up for another 18 months with Direct TV. Didn't have to have splitter to just get Satalite so that wasn't the problem at all. Any of the splitters I had would have worked.
Posted on Apr 22, 2009
How do I hook this tv up with a cable box?
  1. Turn off and unplug the TV and cable box. ...
  2. Hook up one end of a coaxial cable to the cable wall outlet and the other end of this cable to the back of the cable box using the "In" jack.
  3. Connect one end of the RCA audio/video cable to the back of the cable box using the "Audio/Video Out" jacks.
Nov 05, 2017 | Televison & Video
How do I connect the Norstar M7324 telephone to an expansion set?
Your expansion box is a CAP (central answer position) module. I will assume you are using the same jack as before. The line cord, from phone to jack should be 6 conductor (count pins on end). A short line cord runs from back of phone to back of CAP (plugs on CAP are labelled) then the longer cord runs from CAP to the wall jack.
Sep 12, 2014 | NorStar M7324 Telephone
Hello, I have a philips 107e61 ,17" crt monitor and it has a problem with the VGA cable. The image appeares and disappeares when I move the jack or the cable. It seems that the wires inside the VGA jack...
Standard VGA (with DDC VESA) pins are H-Sync = 13 and V-Sync = 14. R G B are 1, 2, and 3 respectively. Ground is 5, Red Shield 6, Green Shield 7, Blue Shield 8, 5V 9 (if there is a pin in the connector), Sync Return 10. 4, 11, 12 are ID Bits 2, 0 and 1 respectively, 15 ID Bit 3 (or clock pulse). If your connector does not have anything in 9 and 15, then it is not have DDC VESA.
May 29, 2014 | HP L1502 15" LCD Monitor
What kind of cable to run for HD update?
I ran regular RG6 through my house and both DirecTV and Comcast work just fine. Longest run I have from source to box is about 50' if that factors into your planning.
May 20, 2014 | RCA 12' Quad Shield RG6 Coax Cable...
Coax Cable (RG-6) Split?
You can put a 2 way splitter. I would advise against it, a home is always the best practice. If you do decide to put a splitter, I would recommend that it be put in the box. It may have to be changed and would be wiser not to have to cut into the wall. One again I would recommend a home run to each box. No limitations.
May 26, 2013 | Electrical Supplies
Ive had it for 2 years and sometimes on hd channels the video and sound flickers in and out about 8 or 9 times then will be fine. ive swapped the hdmi around and it still does it. it will not do it on my...
It is your Cable Feed. Secondly, if you have one of the old "Black" Scientific Atlanta boxes roughly 10x8x2, make them exchange it for a Motorolla if possible. Make sure the feed to the cable box is RG-6 Quad shield RG-59 or RG-6 dual shield won't cut it. Then make them meter the feed to the house from the box. If you have the option, Go to FIOS from verizon. No comparason! same price, very, very few headaches! and the service blows cable away!!! If you need further help, post a reply with all the vital info: make, model, etc of your electronics and how old your existing cable to the house and into the house is. It will help alot. Hope this helps!
Jun 16, 2010 | Sony STR-DG820 Receiver
Setting up a new TV
you will receive upwards to 150 channels (depends on how the tv is designed) you will not receive all the channels which you receive on the tv which has the "box". You will need an addtional box if you want to receive essentially any 200 or above channel.
Hope this helps
Apr 12, 2010 | Samsung Televison & Video
Need to know what i need to connect my prewired home (with cat5 cable running from box in garage to jacks in 4 rooms) to the internet. currently just have cable modem in office.
You would need a 4 - 8 port router... with a wire going to each Jack... and these would plug into the Router ports, The router plugs into the Modem. You have to put the Ethernet plugs on each end of the Cat5 cable. Then you setup your network. But if you have a wireless router you simply need each PC WiFi enabled, IE: A wireless card in each PC, that way you do NOT need Cat5. Then each PC, simply connects to the Router/Modem.
Mar 05, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to run cat5 for phone wire
You could, but common practice is to make all the runs "home runs". Pick a closet or basement or some centrally located place and run all the cables to that spot. Then you can use a $10 block from Blowes Home Dumpo Maynards and create a distribution point.
Carl
Aug 21, 2008 | Computers & Internet
Ghosting and popping noises
slag, Has the cable signal been branched off to another TV (or more) from the same feed? Ghosting and shadows are usually the result of bad impedance matches on those lines. Try connecting the prime TV directly to the cable box (or cable jack) output and note if there is any improvement. Make sure the cable itself is of the RG-6 type (not RG-59) and has no sharp bends or kinks. The center pin of the cable should be clean without corrosion. The RF IN jack on the TV should be checked to make sure the threads for the connector are clean and the plug should be attached firmly but not too tight. These steps should help solve this at least assuming the cable signal is good. [Checking it shows the "level" coming off the pole, not necessarily the quality of that level.] Hope this helps.
Oct 31, 2006 | Toshiba 34HF83 34" TV
Televison & Video Logo
183 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
