Question about Sharp EL-1197PIII Calculator
How do i set the time on this calculator? - Sharp EL-1197PIII Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Follow the instructions on the first page of this manual.
Posted on Apr 07, 2013
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
Oct 22, 2012 | Staples SPLP500 Scientific Calculator
How do I set the time on my calculator
To set the time on this calculator, you must press and hold the time key until the display is flashing 0. (Hint: you will want the date displaying when you are going to set the time as when you press the time key to hold it, it will switch over to the time.) Once the display is flashing you type in the time using the keypad. If you were going to set the time for 9:30, you plug in 930 and push the time key again. If you need to set it for a time in the PM you would have to use the 24 hour scale; for example 1:30 PM would be 1330. To set the date, you press and hold the time key with the date displaying until the display begins flashing. Again you would use the numbers on the keypad to enter the date and press the time key again to set it. For 1/20/2011 you would type in 12011.
May 05, 2010 | Victor 1260-2 Calculator
Cannot set date and time
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 29, 2010 | Canon P23-DHIII Calculator
How to set time and date?
Setting the date:
Setting the time:
displayed.
Jan 27, 2010 | Sharp EL-1801P Calculator
Canon P200 DHIII calculator needs to be changed the date. Can you tell me how?
Setting the date:
Setting the time:
displayed.
Jan 22, 2010 | Canon P200-DHIII Calculator
I don't have the manual for my canon p23-dhv calculator. How so you set the date?
Hold down the time set key (M+ key) for 3 seconds. Then hit the date/time key. Enter in the correct date. Hit the time set key again to set. To set the time hit the date/time key twice to bring up the time.
Hope this helps.
Oct 30, 2009 | Canon P23-DHV Calculator
Setting up the AM and Pm of time on calculator
Time has to be entered as in military time:
Example: 3:15 AM = 03:15
or
Example: 3:15 PM = 15:15
The calculator's clock works just like a 24 hour clock and will automatically display AM or PM depending on how you set it up with hours and minutes.
Jul 22, 2008 | Sharp EL-1197P Calculator
Helps with time - - - - what about date - that doesn't seem to work
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Jun 25, 2008 | Office Equipment & Supplies
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
How to set the time and Date-Step by step please
I found this and it seems to work Solution #2posted on Nov 17, 2006 By greeneyes Rank: Guru Rating: 94.81%, 27 votes on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Sep 03, 2007 | Canon P23-DHV Calculator
Sharp EL-1197PIII Calculator Logo
20 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
