Question about Biostar M6VLR PLE133T Socket 370 mATX MB w/Vid (M6VLRA027N293) Motherboard
Not reading the correct memory - Biostar M6VLR PLE133T Socket 370 mATX MB w/Vid (M6VLRA027N293) Motherboard
    Scholar:
  • 122 Answers
Well, depending on what your ram and how much you have installed. This motherboard only supports up to 1gig max.
Memory * 2 x 168-pin SDRAM DIMM
* Maximum 1.0GB
* PC133
No matter how much more ram you install, it will not read more than 1gig.
Posted on Aug 22, 2010
My PC will no longer read the pics on my memory card. What can I do to correct it?
How are you trying to read the memory card on your computer? Do you have the card in a card reader? Or are you connecting your camera to your computer via USB?
Dec 26, 2012 | Canon EOS 600D Rebel T3i Digital Camera...
My nokia e65 memory reads "no memory inserted", but i have a 2gb sd micro which was inserted by the manufacturers. However the memory chip is accessible on the computer . Kindly sort me out
Remove the memory card and check using a memory card adapter on the card reader of the laptop. If the memory works fine with a scan and shows up well on the properties the capacity of the memory.Then replace the card back into the phone using the correct direction. Some times the direction is deceiving and so it might not read. Once in position if the card is not detected, then either the slot has a fault or the motherboard interface is defective.
Sep 18, 2010 | Nokia e65 Cellular Phone
Wont read memory
The memory might be correct, but the server may require matching RAM. Check your hardware specs for details, but you may need two matching modules in the correct banks for the server to recognize and utilize the RAM.
Dec 16, 2009 | HP Compaq ProLiant ML310 Server
Doesn't recognise new memory modules
make sure you have installed it correctly the memory banks (slots) are paired  1 with 2 and 3 with 4 (they should have matching colors)
Apr 24, 2009 | Computers & Internet
Vu doesn't read music from memory card
check the name of the file in the sonng, sometimes if the filename is too long or longer than 20 characters the phone may not read it even if it it saved correctly in the memory card..
Mar 10, 2009 | LG Vu CU920 Cellular Phone
Memory upgrade for Inspiron 1200
your new ram is either bad, or incorrect, speed. Try to copy the working ram for the correct type
Feb 15, 2009 | Dell Inspiron 1200 Notebook
Toshiba satellite a100,wa-1 memory upgrade
Take out all the memory cards and wipe the gold part of the memory modules.
Then insert the two 512 modules & check the memory.
If it shows the correct readings, then the two modules are detected.
Then insert the 1 gb & other one 512 module.
Then use the other one gb with the same 512 & check if it shows the correct readings.
Then the two 2 gb modules are fine.
Now insert the two 1 gb modules & check now.
There are ECC type & non-ECC type memory modules are available, chck which one your computer supports & which type you have.
If it shows the correct readings, then the two modules are detected and fine.
Then you can also swap the slot and check if any memory module is not detectd correctly.
Some have four slots & i dont know how many slots your laptop have.
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Toshiba Satellite A100-S8111TD Notebook
Memory card cannot be read
Well this could come from one of 2 problems that spring to mind...
1. You do not have the correct software installed on your PC, as thus presents a problem in reading said memory card, especially if you are using non-specific or generic software.
Ensure the software you are using is for the Nikon Coolpix S200.
2. The memory card may also be faulty, if you feel this may be the case, i suggest having a dealer or repairer take a look at the card.
Tip: Some photo labs have self service units for most types of digital cameras. Drop in and try establishing if the memory card can be read.
Dec 24, 2007 | Nikon COOLPIX S200 Digital Camera
Memory card problem
Hi I suspect this is due to the printer being unable to read this size of memory card, as i have the same problem, where as it will read a 128mb card but not gb !
Feb 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Biostar M6VLR PLE133T Socket 370 mATX MB w/Vid (M6VLRA027N293) Motherboard Logo
57 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
