Question about Hotpoint Dishwashers
I have no power to hotpoint dishwasher fdf780g, plug fuse ok.
    Problem Solver:
  • 7 Answers
Should be a red reset button on bottom of motor. Remove bottom face plate and you should see it
Posted on Oct 15, 2010
No power getting to machine
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Dec 19, 2011 | Tecnik 18 in. TKD7000 Built-in Dishwasher
Washing machine stopped working,no power,no display checked fuse,fuse ok.hotpoint wt761
Check the power outlet, the plug and the cable or with the appropriate tester see if you have mains power where the power cable connects to the machine wiring.
Jan 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint washer does not turn on
There are four components to check if your washer will not turn on at all. You need to check your power supply, the door switch, the cycle selector switch and the timer motor.
Am suspecting the power supply, Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
That should do the job for you. Hope this helped you.
Jan 14, 2011 | Hotpoint Dishwashers
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
We have Frigidaire 24 in. FDB1050REC dishwasher. The control panel has no power; no lights and nothing works. This problem started after a power outage. All circuit breakers in house ok and other outlets...
more than likely fuse is gone in plug. take dish washer out. change fuse in plug. if it doesnt work get extension lead and run it from a socket that definatly does work and plug washer into that. if nothing then its internal.
Jan 16, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher issues
it can be the 10A fuse located in the back of the machine. but.... storage is kind of a problem with determining what is wrong with it.
Mouse can have chewed the wires, moisture can have rusted or corroded some components.
Check the internal fuse first and please check all wiring fo damage.
May 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint FDW70 dishwasher
Disconect POWER at breaker or fuse panel which should be on a seperate braker. if not find the power sorce and unplug the device. FOR SAFTEY Kneel on a thick doormat if you have to disconect power which has a plug. Wait for a an hour so to let all circuits, timers and motors to cool ... with diswasher in the OFF position, Re-establish POWER. then go ahead and start washer as sugessted by the Manufacturer. Make sure to notice any other codes that may appear. Or any peculiar noises. Most default codes appear if water pressure is too low. Top loaders are natorious for plugged drain lines and can be flushed by the home-ownwr. Make sure to check that water strainer is not cloged or restricted. Hotpoints CODES change from year to year, You can contact a Hotpoint Dealer in your area ... Give him the Make, Model, and any Series numbers to him. MOST will tell you what the CODES ARE FOR THAT MODEL OR EVEN E-MAIL ALL OF THEM TO YOU. Good Luck ... Be Safe Joe Rex
Oct 09, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Blowing fuse
What exactly happened to your machine, before facing this problem?
Aug 27, 2007 | Hotpoint 24 in. DF55 Free-standing...
Dishwashers Logo
303 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
