Question about LG Dryers
Hi, I have an electric LG dryer that I bought in 2007 and I noticed that it doesn't seem to be drying as quickly or as effectively. I vaccumed the exhaust tube and inside the dryer where the filter goes. there did not seem to be an excessive ampunt of lint in either place. It seemed to help a little, but I did notice that the back panel gets really HOT. Is this normal or should I put in a service call? thanks!
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
My dryer Lg Tromm model number DLG5988 is blowing cold air, changed sensor bars still not drying- also the check filter light stays on and it's in cool mode and dry keeps blinking, what could it be?
sensor bars just measure humidity so dryer knows when close are dry, so will have no effect on heating. the check filter light is just a reminder, not connecter to any sensor or anything. could be several issues: gas valve solenoids, thermal fuses, etc. but for a quick try that might work, try just unplugging the dryer, push and hold the on button for about 20 seconds and then plug back in and see if the dryer is reset. works sometimes. good luck
Aug 24, 2015 | LG Dryers
Radio suddenly doesn't work and instrument panel doesn't work
Ok, i had the same problem a few months back, in my case my car was only a year and a half old and had just washed the engine at the local carwash. Fuses were ok and battery was in new condition, we found out that water had reached the Alternator and this messed up the whole electric system, Some people say you can blow dry your alternator (If this is the case) or take it to an electrical technician
Mar 27, 2013 | 2007 Ford Fusion V6
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
I HAVE A FAIRLY NEW LG ELECTRICAL DRYER BUT IS NOT DRYING IS JUST COLD AIR. I NOTICED THAT THE VENT HOSE WASEN'T CONNECTED. CAN THIS BE THE PROBLEM?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 11, 2010 | LG DLE2532W Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
Roper electric dryer. Clothes not drying. Temp ok/timer not?
I would supect a faulty high limit thermostat. This small round device is mounted to a metal plate and attached to the internal ductwork. It can be tested using a multimeter or ohmmeter. Test for continuity. It should have none. Hope this helped and best wishes.
Aug 11, 2009 | Dryers
LG Dryer takes way long to dry
Let's work together to get to the bottom of this problem. begin with these thoughts
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
May 29, 2009 | LG DLE5977 Stainless Steel Electric Dryer
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Wet clothes take two 'trips' to dry.
UNPLUG THE DRYER THEN PRESS THE MORE TIME , AND THE LESS TIME BUTTONS AND THE POWER BUTTON FOR ABOUT 10 SECONDS. THEN WAIT FOR 3-5 MINUTES THEN PLUG THE DRYER BACK UP . SEE IF THAT WORKS BY THAT RESET.
Dec 01, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
152 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
