Question about Maytag MMC5000 Microwave Oven
I have reset everything including the child lock. We were using the timer feature and when cancelled ahead of time, the microwave would not heat the food
  • gaguerriberr Aug 22, 2010
    I tried resetting the microwave as you suggested. It still will not heat the food; any other suggestions.
    President:
  • 4,070 Answers
Hi! If it happens again please try this... Unplug the unit from power source and let it sit for atleast a couple of minutes to reset the system. Plug the unit again and see how it goes. Hope this helps and thank you for using FixYa!
Posted on Aug 22, 2010
  • dj_relly999
    dj_relly999 Aug 22, 2010
    Alright, looks like that the problem will be on the circuit board. There could be blown capacitors causing the unit to fail. May want to take it to any electronic repair center for this will need an on-hand diagnostic and repair.
LG Microwave MC8289UR/00 want to know if has child lock and how to turn on and off
Here is a section of the manual for your microwave on child lock, hope this helps.
"L" - Page 7 Press and hold STOP/CLEAR until " L " appears on the display and a BEEP sound is heard. The CHILD LOCK is now set. The time will disappear on the display . To cancel CHILD LOCK press and hold STOP/CLEAR until " L " disappears. You will hear a BEEP when it's released. If any button is pressed, "L" will appear on the display Your oven has a safety feature that prevents accidental running of the oven. Once the child lock is set, you will be unable to use any functions and no cooking can take place. However your child can still open the oven door. Press STOP/CLEAR. Child Lock 7
Jan 10, 2018 | LG Microwave Ovens
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Child lock on
    This feature detects when your child pushes various buttons.
    To reset/remove this message, disconnect the microwave from the mains power, wait for 30 secs and connect it to the mains power then set the Time and your microwave is ready for use.
    Jan 22, 2012 | Panasonic Microwave Ovens
    Forgot my childproof code now i cant use my microwave how can i get a new one
    Many microwave CHILD LOCK features are activated / disabled by repeatedly pressing one of the function buttons or by holding it down for about 5 seconds.
    Try pressing the STOP / CANCEL button 3 or 4 times in a row to see if you can the CHILD LOCK off.
    If that doesn't work, also try holding down that button down for 5 seconds.
    Try these same two procedures on some of the other buttons as well like the TIMER button, or the START button, or the CLOCK button.
    Your best bet however would be to include the brand and model number with your question next time and then we will be able to locate the exact instructions for you.
    I hope this was helpful.
    Good luck and take care.
    Joe.
    Dec 14, 2011 | Microwave Ovens
    Child sign in window of microwave ,cant start it panasonic
    On my NN-L738BA there is a Child Lock feature.
    You set the child lock by pressing the Start button 3 times.
    If the Child Lock is enabled it displays the word :CHILD".
    To disable this feature on my microwave the manual says to
    press the Stop/Reset 3 times.
    Check your manual for the Child Lock.
    Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
    Unlocking child lock on the sharp microwave model R316FSC
    The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
    Or just unplug it, wait 1 minute, and plug in.
    Jan 06, 2009 | Sharp R-308J Microwave Oven
    Panasonic microwave
    the child lock feature is activated.
    if you can look at your manual, it would be stated there how to activate and deactivate your child lock option.
    tnx 4 using fixya
    drcool
    Sep 01, 2008 | Panasonic NN-S254BF Microwave Oven
    Microwave oven (nn-sd997s) stuck in DEMO mode
    Pressing "timer/clock" button 4 times turns on and off demo mode.
    Apr 26, 2008 | Microwave Ovens
    Microwave just totally stopped working
    It's probably a bad door switch or it's loose in its mount. I have complete help text files on safety, disassembly and door switches. With help from those, you or a friend can safety disassemble the unit to check and replace the door switches. You can find me via a search on Yahoo.com (not Google) for microwave circuit repair
    Dec 05, 2006 | Maytag MMC5000 Microwave Oven
    Maytag MMC5000 Microwave Oven Logo
    27 people viewed this question
    Top Maytag Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
