Question about Spirit Exercise & Fitness
We have a Spirit SS185 treadmill that makes a grinding noise when it's turned on and runs really slow for a few seconds then speeds up really fast for a few seconds. We've had this treadmill for several years. Is it worth repairing?
4 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
SOURCE: Lowest speed of elite personal trainer tm500 too fast.
It requires a drive belt adjustment. Gain access to the motor and belt (Disconnect from power supply first!) and reajust belt tension.
email me on mickey67@tpg.com.au if you need help. It's not too difficult a job.
Posted on Jul 26, 2010
SOURCE: new free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Posted on Jan 18, 2011
Spirit treadmill model SR225 is this a 1.5 in speed? I need the slow model for mom.
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience. check for treadmill articles.
Mar 14, 2016 | Spirit Exercise & Fitness
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
When on treadmill there is a "studder"
Check if the running belt is lubricated. You can't run an engine without oil. So, spray a good quality silicone lubricant on the base of the running belt. It is best if you spray on a lint free cloth just enough to make a wet patch. Do it outside so that no spray residue lands on the floor and becomes slippery or lands on the carpet and stains it, then return inside and lift the treadmill running belt and soak or smear the base with the wet patch of the cloth and run for a full minute. Then lift the belt again and give it another swipe on the entire base, then feel the base with your fingers or hand to see if it feels wet and smooth. Run the treadmill for another minute at slow speed, otherwise the liquid can fly and splatter on wall or floor. If it still hasn't solved the problem, then it must be the motor brushes, or it may be set to run slow and fast according to the running settings on the console. Mine does the same thing if it is programmed to do 1 minute slow and one minute a bit faster. Good luck.
Jul 30, 2014 | Proform Crosswalk 395 Treadmill
Technofit ts500I treadmill When its running the treadmill starts and runs fine. However when I get on it, it the speed becomes jerky running slow fast slow fast making it impossible to use.
If someone spilled a drink on the belt, it will become sticky as it dries. The belt will try to stick to the bed of the treadmill. Loosen belt, wipe clean the bed, underside of belt, and end rollers.
Apr 24, 2014 | Exercise & Fitness
Makes a loud rubbing noise on one side
To be honest with you, these could be symptoms of a few different problems. Here are the most common ones and what it possibly sounds like:
1) It could be that the front roller has dislodged itself from the roller pulley. In other words, the motor keeps turning, and when you step on the walk belt, the pulley (the one with the small rubber belt) keeps turning, but the roller stops. This can cause grinding noises, and the pulley to "skid" the black belt, which can account for the black dust. You can usually tell this is the problem when it runs fine with nobody on it, but when you step on it, it grinds
2) It could also be that the walk belt is rubbing on the sides of the deck and/or side rails. This happens when the belt shifts over from the center. It would definitely sound like a grinding noise, and the black dust could be from the walk belt particles wearing down due to the rubbing.
3) It could also be the drive motor brushes. Let me explain. The motor has two small blocks on either side of it (inside the metal casing). Those two blocks actually carry electricity into the spinning part of the motor (called an armature). They actually make contact with the armature at all times while it spins. Those "small blocks" are made of a graphite (what pencil lead is made of). Well, with so much spinning, and so much contact from the armature, those things grind down with time. They sometimes grind down until they are stubs only. Then they start grinding. The powder in this case would be the brush graphite piling up (this would often be shiny dust, and is a dark grayish).
4) The grinding could also be roller bearings going bad.
**For #3, and 4 above, you have but to remove the small belt that attaches to the motor (rubber, black, and small attached to pulleys), and let the treadmill run for a few seconds by itself. You may get a "speed error code' after the treadmill does not detect speed, but at least you'll know if the grinding is coming from the motor. If it runs super quiet, even for a few seconds, then you know it may be #1, 2, or 4 above.
These are the most common issues based on your symptoms.
Mar 16, 2014 | Bowflex TreadClimber TC5000
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
STAND MIXER SPINS FOR A SECOND OR SO THEN STOPS
can you clarify a little more, it is either a gear problem or an electric problem, are there any other symptoms? Like sound noises, grinding fast speed when it does run for those few seconds or really slow. if it is running fine while it does run then it is more likely a speed plat or phase control board. please let us know
Sep 13, 2012 | Food Mixers
Treadmill slows down Free Spirit Mod.#122300800
make sure you are not in a program. Can you speed it back up?
Feb 05, 2009 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
219 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Mister G
Mister G
Level 1 Expert
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
