Question about Sharp LL T19D1-B (Black) 19" LCD Monitor
Monitor says out off sync - Sharp LL T19D1-B (Black) 19" LCD Monitor
  • Jack
    Jack Aug 22, 2010
    does this message apper when you connect the monitor to the computer and the computer is om
  • 11,361 Answers
You need to set your PC video resolution to the native resolution of this monitor for best picture, please see your manual.
Right now the resolution is too high for the monitor to display.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 22, 2010
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
I can't get the monitor and the camera to sync.
Turn on your monitor and camera. Click the menu button and choose, add camera. As soon as you do, push the "code" button in on the back of the camera. You should see a picture soon after.
Aug 23, 2010 | Summer Infant Slim Secure Handheld Video...
My samsung 750s monitor has a message saying sync. out of range
When you turn off the pc the monitor loses the sync signal and should go into a suspend mode where the screen is blanked. The power management settings should be checked. In display properties check that the monitor is installed correctly.
Jun 06, 2010 | Samsung SyncMaster 750S Monitor
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Hi, I am having Samsung LCD sync master 943nwx, after power on momentarily display is coming and going,
it may simply be a lose connection with the monitor cord. or the monitor cord may to be replaced.
Jul 12, 2009 | Samsung 15.3" LCD Monitor
Monitor problem
try running your OS on safe mode then reconfigure your monitor on the display settings and adjust the screen resolution to sync your monitor with your video card.
Sep 02, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
How to use a sync
Sync is usually an option on the Video Adapter.
Usually, set it on or off, or a scale, (default, never, application).
On the monitor, check the manual, and perhaps with others, setting sync on the monitor, has in the past, given me some problems.
Dec 19, 2007 | ASUS P4GE-MX Motherboard
Sharp LL T19D1-B (Black) 19" LCD Monitor Logo
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
