Question about Whirlpool Refrigerators
My refrigerator not working but inside light is working.can you tell me what is the problem
    President:
  • 949 Answers
If your lights are on and nothing is running (no fan, no cooling etc) the problem is one of two components, either the the thermostat (cold control) or the defrost control.
A test for continuity across the cold control will tell you if that component is good. The defrost control can be checked in a similar manner.
Both components are worth replacing and I would have it repaired rather than replaced.
Posted on Aug 22, 2010
We have a Samsung side by side and it just quit working. The only thing that is on is thr ice cube symbol that is flasing. The lights on the inside is also on. but nothing is runing
try unplugging count to 10 then plug back in, if this fix works you just rebooted the computer main control. located in back of fridge. then you will see 88 or something like this on display. this should be gone in 24 hrs. if not call samsung tell them what is display look like they should be able to tell you what is wrong
Sep 23, 2014 | Samsung Refrigerators
Where is the filter located in the refrigerator?
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Jan 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The lights (3) does not work on the frig side of my Whirlpool side by side. The door switch checks out fine.
i hate to tell you this,but you will need the new motherboard to fix this problem,they are notorious for doing this,the board is located in the rear area inside the unit inside a plastic box with a cover and has 2 to 3 harnesses yoy unplug and replug in,some clues to this are:lights that burned out and you replaced and now either dimly strobe or do nothing and the refrigerator compartment does not cool and the digital temp read-out if equipped is dark now also,the board is about $90
Apr 16, 2010 | Whirlpool GS6NBEXR Side by Side...
Just stopped working: plugged in,light on,fan blows in freezer-
defrost timer probably failed in defrost mode go online search for defrost timer location and manually advancing or initiating a defrost cycle , it may pop into run mode and tell you thats what it is , 90% of the time thats it and they are cheap !
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
Frigidaire refrigerator not working colling
Can you tell me a little more like sounds of fans or compressor sounds. Lights on inside. When you open freezer is fan running? I will give you a try on fixing this. Let me know also if the model number above your post is the model of your refrigerator. Let me know if I can help you, Thanks, Sea Breeze
Jun 18, 2009 | Frigidaire FRS26R4A Side by Side...
Light off
probably just the bulb. look in yoiur instruction book and it will tell you how to replace. usually just a matter of removing the cover over the light
Jun 08, 2008 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Refrigerators Logo
50 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
