Question about Asus Eee 701Sd Notebook
Switch on eeepc says press f10 shift to configure nothing happens
    Guru:
  • 689 Answers
I think you may have changed your bios (F2)settings inadvertantly-------you may have enabled an extra boot process which you dont necesserely need----go back to bios settings and switch of this boot process--reboot a couple of times to make sure it has changed of choose the "return to default settings"
Posted on Sep 03, 2010
SIR, I wish to known MS Office 2007 advance functining & sortcuts
Function keysTo do this Press
Get Help or visit Microsoft Office Online. F1
Move text or graphics. F2
Repeat the last action. F4
Choose the Go To command (Home tab). F5
Go to the next pane or frame. F6
Choose the Spelling command (Review tab). F7
Extend a selection. F8
Update the selected fields. F9
Show KeyTips. F10
Go to the next field. F11
Choose the Save As command (Microsoft Office Button ). F12
SHIFT+Function keyTo do this Press
Start context-sensitive Help or reveal formatting. SHIFT+F1
Copy text. SHIFT+F2
Change the case of letters. SHIFT+F3
Repeat a Find or Go To action. SHIFT+F4
Move to the last change. SHIFT+F5
Go to the previous pane or frame (after pressing F6). SHIFT+F6
Choose the Thesaurus command (Review tab, Proofing group). SHIFT+F7
Shrink a selection. SHIFT+F8
Switch between a field code and its result. SHIFT+F9
Display a shortcut menu. SHIFT+F10
Go to the previous field. SHIFT+F11
Choose the Save command (Microsoft Office Button ). SHIFT+F12
CTRL+Function keyTo do this Press
Choose the Print Preview command (Microsoft Office Button ). CTRL+F2
Cut to the Spike. CTRL+F3
Close the window. CTRL+F4
Go to the next window. CTRL+F6
Insert an empty field. CTRL+F9
Maximize the document window. CTRL+F10
Lock a field. CTRL+F11
Choose the Open command (Microsoft Office Button ). CTRL+F12
CTRL+SHIFT+Function keyTo do this Press
Insert the contents of the Spike. CTRL+SHIFT+F3
Edit a bookmark. CTRL+SHIFT+F5
Go to the previous window. CTRL+SHIFT+F6
Update linked information in an Office Word 2007 source document. CTRL+SHIFT+F7
Extend a selection or block. CTRL+SHIFT+F8, and then press an arrow key
Unlink a field. CTRL+SHIFT+F9
Unlock a field. CTRL+SHIFT+F11
Choose the Print command (Microsoft Office Button ). CTRL+SHIFT+F12
ALT+Function keyTo do this Press
Go to the next field. ALT+F1
Create a new Building Block. ALT+F3
Exit Office Word 2007. ALT+F4
Restore the program window size. ALT+F5
Move from an open dialog box back to the document, for dialog boxes such as Find and Replace that support this behavior. ALT+F6
Find the next misspelling or grammatical error. ALT+F7
Run a macro. ALT+F8
Switch between all field codes and their results. ALT+F9
Maximize the program window. ALT+F10
Display Microsoft Visual Basic code. ALT+F11
ALT+SHIFT+Function keyTo do this Press
Go to the previous field. ALT+SHIFT+F1
Choose the Save command (Microsoft Office Button ). ALT+SHIFT+F2
Display the Research task pane. ALT+SHIFT+F7
Run GOTOBUTTON or MACROBUTTON from the field that displays the field results. ALT+SHIFT+F9
Display a menu or message for a smart tag. ALT+SHIFT+F10
CTRL+ALT+Function keyTo do this Press
Display Microsoft System Information. CTRL+ALT+F1
Choose the Open command (Microsoft Office Button ). CTRL+ALT+F2
Jan 05, 2011 | Microsoft Office Computers & Internet
Want to reset my daughters eeepc to factory setting tryed pressing f9 but nothing is happening can u plz help is their any other way thanking nu
press f2 disable the booster boot
if still nothing, try all f keys, tab and space bar also have default settings on some
last is install windows xp on a usb flash drive if you dont have the dvd /cd restore disk
Sep 17, 2010 | ASUS Eee PC 900 Notebook
When starting up my eeepc 904hd it takes me to the screen asking if i want to start as normal or use safe mode or continue you from an earlier point wean i click any of these it comes up windows then the...
try to choose last known configuration that worked...is the second from the bottom ...and if it gives you blue screen again ..it measn that it is a hardware issue ..try to go to bios when you start it ..by pressing F2 immediately ..and there choose optimal factory defaults ..and than F10 to save the changes...after that ..start it again and try to see what happens ..if it still do not what to boot you have to try reinstalling it ...but go to a professional if it is a kinda eee with no optical drive ..cause you need a boot-able memory flash drive....to reinstall it ..
May 12, 2010 | Acer Aspire One PC Notebook
Connect tv to eeepc 701sd
hold down the keys for a few seconds ,make sure you havent pressed Fn-F1 in error as this will put the eeepc into suspend/sleep mode
Feb 01, 2010 | ASUS Eee PC 701 Notebook
EeePC 701 that no longer detects wireless access points
some eeepcs have an auto-down load facility that upgrades certain items(firefox for example) andother items ,i found once i had upgraded these items the wi-fi wouldnt enable as efficiently as before--i can't point you to specific code but if you re-install the OS(Linux Xandros) from base and switch off the updates,by going to "settings" then choose "installing/removing software" then choose "preferences" you can partially stop these auto-downloads and from a new base configuration install you might find your wi-fi works again.
press F9 whilst booting to get to the install OS screen ,you will have three choices whichever you choose (highlight) then press "E" then press "B" and this is how you re-install
Sep 25, 2009 | ASUS Eee PC 701SD
Didnt install the camera i want to install it asus notebook
One of two solutions:
1) Enabling the EeePC Camera through the BIOS
Go into the BIOS Setup (press F2 when the screen lites up).
Right arrow key to Advanced
Down Arrow key to Onboard Devices Configuration
Enter
Arrow key down to Onboard Camera
Enter
Arrow key to Enable
Enter key
F10
Enter
2) You need to download the webcam driver from the Asus website.
Jan 27, 2009 | ASUS Eee 4G Notebook
No educational progams on pc
I have both Linux and Windows XP versions of the EeePCs. And the Linux version comes with some educational software. While the Windows XP version does not.
The vast majority of no webcam is because it is toggled off in the BIOS.
Enter
Enter
Arrow key to Enable
Enter key
F10
Enter
Hopefully that takes care of it. :)
Jan 14, 2009 | ASUS Eee 4G Notebook
LAPTOP HP G5000
When you press F10 to enter the set up nothing happens, is that correct, and what does the beep sound like? Also, does it beep if you don't press anything, and after the initial screen with the F10 message, what does it do?
Jul 04, 2008 | Computers & Internet
Asus Eee 701Sd Notebook Logo
207 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
