The picture on my monitor is blurred n dull n d brightness cant b adjusted!
    Scholar:
  • 122 Answers
Monitor issue is not a Barcode Scanner problem.
Now then...go to your control panel/hardware and sound/display.
There should be options to change brightness and resolution as well.
Blurred issue you might want to make the resolution higher.
Brightness issue, manually change the brightness from your video options where I have stated at the first.
Posted on Aug 22, 2010
Hi I have a Samsung 56V monitor . The letters have been appearing blurred for quite some time .
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull...blurr... (less brightness & less contrast , no clarity ) ........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily..
May 14, 2011 | SAMTRON 55V 15" CRT Monitor
Hello I have monitor samsung Smatron 7Ei the fault is that the picture is very dull with less contrast and bright. CRT heater volgate is ok. Secondly there is a heavy noice when i start it by power...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull (less brightness & less contrast --- that noise is from EHT )........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.....
Apr 18, 2011 | SAMTRON 55V 15" CRT Monitor
TEXTS ARE TOO BLURRED AND BRIGHT ,IRRITATING TO THE EYES
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull (less brightness & less contrast , blurness )........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( very much compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily....
Apr 04, 2011 | SAMTRON 55V 15" CRT Monitor
We could not see the monitor letters cant read
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull (less brightness & less contrast , no clarity ) ........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily..
Feb 17, 2011 | Samsung 793S 17" CRT Monitor
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Monitor brightness and switch
You can do this by control panel or going to your desktop>right click>properties> and montior then adjust stuff from there
Feb 22, 2010 | Dell E196FP 19" LCD Monitor
Blurred screen on monitor
If that dont work then try to change your other settings on your monitor
Apr 24, 2009 | Computers & Internet
LG FLATRON 915FT plus monitor OSD setting
1. clean the G4 wire.
2. change the neck base.
3. adjust the focus preset in LOT .
Oct 16, 2008 | LG Computers & Internet
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Toshiba 53" Dull Screen. No brightness and Contrast.
I would guess the tubes are going...I would still have serviceman check it out
Oct 20, 2007 | Toshiba 53H71 53 in. Rear Projection...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
