Question about Miele 24 in. Novotronic G641 Plus Built-In Dishwasher
My Miele G641 displays the Salt PC light even after filling it with salt. I have to cycle the main power switch 3 or 4 times before the Start light will come on. Then when I press the Start button it momentarily pumps out water and then stops. Sometimes the Start light stays on and I can get it to give the pump another brief spurt, but often the Salt/PC light comes on again and the Start light goes out. I then have to re-set the power switch. How do I tell if the logic board is fried?
  • Miele Master
  • 19,396 Answers
Hi.
This is not a PC, when logic board is fried the machine does not start at all rather than doing weird thing.The logic board is not fried, in the worst case the salt sensor is jammed.
Try first pouring a couple of litres of hot water on top of the salt reservoir (that must be done normally after refilling salt). After that you can reset the machine by tripping the circuit breaker.
If that does not work, pour water until you clean completely the reservoir from salt. Run a couple of cycles with no salt, reset. Put new salt and pour water on top.
Start a cycle.
See other testimonials with same problem here.
Posted on Aug 22, 2010
How do i add salt to miele incognito?
There is a cap inside the dishwasher on the bottom right side, unscrew it and dump a full box of salt in. Clean up any spilled salt and run a rinse and hold cycle to remove any salt residue. Miele recommends using their own salt, available online at www.mieleusa.com or at a local Miele dealer. They don't recommend using water softener salt or table salt. For more help call their tech support at 800.999.1360, they are very helpful.
Mar 31, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
What is the salt when it comes to the dishwasher
The light is just to let you know that the internal water softener needs water-softener salt.
If you do not use the softener (I do not at my house) then the light serves as a convenient on/off light.
Feb 17, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
I have just purchased a new Miele dishwasher. I filled the salt reserve as required but whenever the cleaning cycle finishes it reads Add salt! The salt reserve is already full! Please could you...
Hi Carol
You MUST add water into the softener reserve chamber, normally water first then salt.
Dont worry its a common mistake.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Miele Dishwashers
Inlet/drain, salt and rinse aid light flashing also water left in base of machine after it stops
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 06, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
I have a Miele G641 dishwasher and it wont drain and it is coming up with red lights saying inlet/outlet, salt intake
One thing these guys did not point out is to turn the knob to STOP before starting this procedure (otherwise you will be ignored) Once done this works fine.
-- from the manual ----------------
Before rectifying the problem you must:
- Turn the programme selector to the "Stop" position.
- Switch the dishwasher off using the "On/Off" button.
Nov 15, 2009 | Miele 24 in. Novotronic G641 Plus Built-In...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Salt light on G641 model
i turn the dishwasher on the salt light keeps flashin ive cleared out the salt container and applied new salt and its still not working
Jul 08, 2008 | Miele Premier-Plus Built-in Dishwasher
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele dishwasher film and crust on the inside-
Hard water has this "crust" which are minerals floating around that ionically attach to everything. Some machines from Miele have a water softener inside the machine. Special dishwasher softener Salt is added that cleans minerals off Xeolite beads. When cleaned they attract mineral ions. If you don't use the salt then the beads fill up on minerals until they can't hold any more minerals. The salt is used in the regeneration cycle. It washes the mineral ions off the xeloite replacing them with salt ions. As new water enters the machine mineral ions slowly knock off the salt ions and attach themselves to the beads again. This whole process keeps the crust off the dishes and the walls of the machine.
Use a dishwasher cleaner that removes scale. And if you don't have a salt light on your Miele you can instead purchase soap tablets that contain water softener built in. Miele dishwasher tablets have it. You can order them online or call Miele.
Dec 17, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Dec 07, 2007 | Dishwashers
Miele 24 in. Novotronic G641 Plus Built-In Dishwasher Logo
413 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
