The icons on the desktop disappeared, I have some icons on the taskbar but they do not open the programs.I tried: 1. right -click the desktop-Arrange Icons By- click Show Desktop Icons then 2. right click desktop-Properties- CustomozeDesktop-selected some icons and 3. right click taskbar-under Notification click Customize- check the always show all icons and...-nothing worked. What else can I do? I cannot use my PC at all.
    Sergeant:
  • 201 Answers
Hi try system restore .take it beyond the date when your problem first began.(do system restore in safe mode)this sounds like a virus ..i,ve done this before and it worked .if this dosen,t work you can reverse this action..another remedy is a good propriatry virus remover like; trojan remover; or bart pe.this ones used through your optical drive.failing all this reinstall a fresh set of windows.hope this helps.
Posted on Aug 22, 2010
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
Icons are missing from computer screen
A.
  1. Right-click the desktop.
  2. Point to Arrange Icons By.
  3. Click Show Desktop Icons.
B. To re-create the Show desktop icon yourself, follow these steps:
  1. Click Start, click Run, type notepad in the Open box, and then click OK.
  2. Carefully copy and then paste the following text into the Notepad window:[Shell]
    Command=2
    IconFile=explorer.exe,3
    [Taskbar]
    Command=ToggleDesktop
  3. On the File menu, click Save As, and then save the file to your desktop as "Show desktop.scf". TheShow desktop icon is created on your desktop.
  4. Click and then drag the Show desktop icon to your Quick Launch toolbar.
Feb 05, 2012 | Microsoft Windows XP Home Edition
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
A simple free program that can hide/restore icons on my desktop
Hi hugh hinds....
Try this easy solution to your problem
Please take time to rate me
Hiding Desktop Icons in Windows XPWith a good choice of wallpaper, your computer desktop can add an attractive, even artistic, element to your home or office. Eye-catching desktop wallpaper can be as decorative in its way as a painting or other wall hanging.
If you value the aesthetic potential of your desktop, you might like to enhance it even further by hiding the desktop icons.
Hiding or showing your desktop icons in Windows XP is a simple, two-click procedure.
To hide desktop icons:
  1. Right-click on the desktop and open the "Arrange Icons By" sub-menu.
  2. In the sub-menu, click "Show Desktop Icons" to uncheck it.
The icons should disappear to leave a clean, uncluttered desktop. To show desktop icons again, repeat the above procedure. When the icons are hidden, clicking on "Show Desktop Icons" will enable the option and the icons will reappear.
1...Right-click on the desktop and open the "Arrange Icons By" sub-menu.
2...In the sub-menu, click "Show Desktop Icons" to uncheck it.
Aug 23, 2011 | Computers & Internet
Our toshiba laptop turns on but we only have our background pic with no programs on screen
you might have hidden your icons by accident. Try right-clicking and in Windows XP, "arrange by" and make sure there is a check-mark by "show desktop icons"
In Vista and Windows 7 rick-click select "view" and make sure that "show desktop icons" is checked.
If this does not help, make sure that Explorer is started (you should have the taskbar, start buttons, etc. in view of the screen. If not it might indicate a problem with windows itself.
Dec 31, 2010 | Computers & Internet
Why did the icons desappeared?
There are reasons why the icons of your computer disappeared.
1. It could have been hidden if the "Show Desktop Icons" has been disabled.
You can check the settings when you right click on your desktop, and select arrange icons by.
2. Or the virus could have modified your registry settings so the icons disappeared.
Feb 03, 2010 | HP W2207H 22 Notebook
Cannot see desktop
JUST OPEN YOUR WINDOWS AND RIGHT CLICK ON YOUR DESKTOP GO TO ARRANGE ICONS BY AND THEN CLICK SHOW DESKTOP. YOUR DESKTOP WILL BE SHOWN.
IF STILL HAVE PROBLEM AGAIN RIGHT CLICK ON DESKTOP GO TO PROPERTIES CLICK-> DESKTOP-> CUSTOMISE DESKTOP-> GENERAL AND CHECK ALL UNCHECKED ITEMS AND CLICK OK.
IF STILL HAVE PROBLEM YOU JUST NEED TO REINSTALL YOUR WINDOWS TO SOLVE THE PROBLEM.
THIS WILL DEFINETELY SOLVE YOUR PROBLEM.
BYE
PLS. RATE MY SOLUTION
KETAN
Feb 18, 2009 | Microsoft Windows Vista Ultimate Edition
Cannot view desktop
BYE
KETAN.
Feb 18, 2009 | Microsoft Windows Vista Home Premium with...
Desktop Icons
Right click your desktop, click "Arrange icons by" then check show desktop icons.
That should do it..
Jan 22, 2008 | Toshiba Satellite A105 Notebook
Desktop icons
your problem is so simple just listen see below
1.go to desktop
2. right click there
3.open arrange icon by
4.then in second last their is lock desktop icon
5. click their your prob is solved
if go to desktop right click their and click properties
then click desktop
then click customise desktop in web their is lock desktop icon put tick out from their your prob is solved enjoy
Nov 15, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
