Question about Linksys Wireless-G WRT54G Router
Dsconnection problem on linksys wrt54g
When a new pc or laptop access the router the router will reset for a few seconds i have observed this thru the orange light it will turn off for a few seconds then turn on again. is there a way to solve this? if possible i want the router to not reset whenever a new computer or laptop access it please help... ty
  • richtrajano May 04, 2008
    i think it resets because the other laptops acquire ip address for themselves. my laptop is connected via lan port while the other laptops thru wireless is there a setting that the router will not reset or the orange light will not go out for a few seconds because even if i am connected thru lan the connection will timeout if the orange light will blink out for a few seconds pls help me with this.. ty
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Why do you think it resets? You can't go by the lights unless it is the power light and that shouldn't ever happen if plugged in properly. Do the other pcs lose their connection at that exact time? Please give me some other details. Thanks rich.
  • 558 Answers
I will assume that the nat table is rebuilding.
Posted on May 04, 2008
Router needs to be reset
if it need to be reset why dont you just reset it?. theres a small hole that you can fit a paperclip into usally around the power on/off switch. if this isnt what you need help with please be more specific
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
I have the Linksys WRT54G router hooked up thru Ethernet to my desktop PC with Windows XP. I go thru a cable modem to the internet. I have 2 laptops, both with Windows Vista on, wirelessly linked to to the...
Low or poor signal is mainly caused by the following major factors:
Going Around Physical Obstructions
Wireless networks are also susceptible to obstructions that may lead to low signal. Often, the signal gets reflected, refracted or absorbed by the obstruction.
Common obstructions are:
  • Cabinets
  • Mirrors
  • Glasses
  • Metal objects
  • Thick walls and ceilings
If you have any of these objects between your wireless adapter and access point, consider relocating your access point somewhere high to get around the obstruction.
Aug 05, 2010 | Linksys Wireless-G WRT54G Router
I changed my password but I forgot it
Do you have a Linksys router and you have forgotten your password or you want to reset the password to the default. Firstly you must have physical access to the router. This article is basically for WRT54g and model BEFW11S4
If you have changed the password from the default password and have forgotten the default or your router did not come with any documentation.
To regain access to the router try the following. In the username field leaveit blank and in the password field type admin
Username / leave blank
password / admin
The Rest Button on a Linksys Router
To reset the router
While the back of your router might look different, the reset button is usually clearly marked. To reset the router to the default password, insert something thin--like a pencil point--and depress the red button. Hold that for a few seconds. The password for your Linksys router should have reverted to its default.
Try accessing it from a machine that is plugged directly into it. The default address is usually http://192.168.1.1. When you gain access to the router then you can change the password to any word of your choice.
May 28, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
I forgot my security key or passphraseto access my laptop ,can you assist ?
Hold the reset button on the router for about 10 seconds. Then just input a new password into the router. Save it this time ;)
Oct 22, 2009 | Linksys Wireless-G WRT54G Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
My laptop wont connect wireless thru linksys anymore
Reset the router using the little reset button on the back. (Hold for a few seconds) It should be able to connect using default settings. Then you can log on and configure it with your router. Go to http://192.168.1.1 and you can set up your security and port forwarding if needed. (I recommend WPA or WPA2 for security, as I have cracked WEP passwords myself using brute force.) Let me know how this works out. If it doesn't work, I need more info such as your wireless network card model.
Apr 03, 2009 | Linksys Wireless-G WRT54G Router
Linksys router problem
Try a factory reset on the router, in most cases this can be done by holding the reset button on the unit down for 10 or more seconds. Once this is done you may have to enter any settings into the router again.
Also, try download the latest firmware from http://www.linksys.com and upgrade the firmware on the router.
Dec 08, 2008 | Linksys Wireless-G WRT54G Router
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Nov 07, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Router with ethernet connection & wireless. Has been working perfectly for ages with a wireless laptop & Samsung i600 phone. whether coincidence or not a few days ago I logged someone else's...
looks like the new laptop has been assigned the same ip address as your old latop so it wont allow u access...renew the ip address, assign ur old lap top a new one or just reboot the router so it will issue u with a new ip address.
Feb 15, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
89 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
