Question about Magic Stitch Mechanical Sewing Machine
I just bought the singer stitch sew quick and my needle keeps unthreading.
My needle bar driving arm on my Singer 457 has no tension. Without tension I cannot adjust the stitch length or needle position.
Unthread the machine, RAISE the presser foot, and re-thread from the beginning. Verify the thread path is correct.
If this doesn't work, the tension disk may need adjustment or repair.
Nov 15, 2016 | Singer Sewing Machines
What way are we supposed to put in the replacement needle in a singer stitch sew quick machine? The loop stitch isn't looping
The needle should be inserted so that the flat side faces the front of the Sew Quick. (The flat side should face the set screw that secures the needle in the Sew Quick.) See figure 11 (on page 2) of the manual. One link to the manual is currently: http://www.hayneedle.com/images/PDF/MICL002.pdf . Make sure that you are using the DHx1 needle.
If the stitches still aren't looping, make sure that you have threaded the needle and bobbin correctly. The thread should start at the back of the needle and be pulled to the front.
I hope this helps.
Aug 17, 2016 | Singer Sewing Machines
Why does my needle keep coming unthreaded? It sews 2-5 stitches then my needle cones unthreaded.
check that your needle is in the right way ie. with the flat face facing away from you. Is you tension correct? that is doe the sewing look okay?
Oct 30, 2014 | Simplicity Sewing Machines
What is the difference in the length of the needle on a "handy stitch" as opposed to the "stitch sew quick machine?
Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
Aug 04, 2014 | Singer Handy Stitch Hand Held Portable...
Singer 27
What kind of thread are you using. The most often problem today is that the thread is too thick for the size of needle. Try using a Metallica size 90 or a top stitching needle size 90
if the thread is a cotton type or a quilting thread it is often to thick to travel easily through the eye of a needle quickly to form a good stitch.
Aug 03, 2014 | Singer Sewing Machines
My needle keeps coming unthreaded when sewing
normally when you use longer thread tails of 4 to 6 inches and move
the thread tails behind the needle before starting to sew.
Mar 07, 2013 | Singer 7436 - INGENUITY
Sewing machine either breaks thread or comes unthreaded every time i try to sew.
Your threading is not right, totally remove your thread and rethread according to the manual directions and dvd. If, you still have problems call Singer at 1-800-4singer
Sep 29, 2008 | Singer 3116 Simple
Singer sewing machine
If you are using a threadcutter on the Left side of the machine, it may not leave enough slack when you go to start a new stitch, and as the needle decends, the thread is pulled through the eye.
Just try to pull a little more thread through before you recommence.......just why manufacturers would locate a threadcutter where it will not quite allow enough slack thread for the needle to move down for the next stitch without unthreading the needle is one of life's great imponderables.
Bargainbox
Jan 18, 2008 | Singer Featherweight II 117
Magic Stitch Mechanical Sewing Machine Logo
183 people viewed this question
Top Magic Sewing Machines Experts
R.A. Ellis
R.A. Ellis
Tom Chichester
ka4iup
ka4iup
Are you a Magic Sewing Machine Expert? Answer questions, earn points and help others
