Question about DeLonghi Microwave Ovens
How to set clock on DMX65 - DeLonghi Microwave Ovens
How might I set the clock on toshiba er7900
There are different patterns to setting a microwave clokc, depnding on the brand
and age.
Try these combinations (both with the door open and with door closed) to set the
clock to 1:00:
Clock > 1 > 0 > 0 > Start
Clock > 1 > 0 > 0 > Clock
Clock > Clear > 1 > 0 > 0 > Start
Clear > Clock > 1 > 0 > 0 > Start
Apr 27, 2013 | Microwave Ovens
How do I set the clock
On some Galanz models setting the clock is a bit unusual.
You have to press the clock/preset button once then press pause/clear. Now it is in Clock mode setting and you can set the hour then press clock/preset again to set the minutes then press once more clock/prest to finish the operation.
Mar 27, 2013 | Microwave Ovens
How do i fit a new bulb in my microwave model dmx65
All you need is to remove the top panel screws and remove the top panel after disconnecting the power. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
The bulb is located at the top and faces to the inner chamber . You can unscrew from the holder and replace with the same type and wattage.
Aug 22, 2011 | DeLonghi Microwave Ovens
I cannot get the clock-setting procedure to work......
To set the clock to 4:30, for example:
CLOCK > 4 > 3 > 0 > CLOCK
- or -
CLOCK > 2 > 4 > 3 > 0 > CLOCK
(the two means you're setting the clock, as opposed to 1, which would be to set the timer)
Jun 06, 2011 | Sharp R-1480 Microwave Oven
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
I bought a microwave model no:dmx65 but it won't warm the lights came on the time is set but its not heating up what should i do
If it's within the return period for a new purchase, I would take it back.
If not, and it's still under warranty, you'll have to contact the manufacturer to find the nearest authorized service center.
Technically speaking, it may be a bad door switch or switch mount, a problem on the control panel, or in the high voltage parts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | DeLonghi Microwave Ovens
Setting clock
In most brands, you set the clock by one of these combinations of key presses:
Apr 22, 2008 | Microwave Ovens
Clock Problem
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have the manual, the usual sequenceof clock setting is one of these:
Clock > digits> Clock
Clock > digits> Start
Clear > Clock > digits> Clock
Clear > Clock > digits> Start
Clock > Clear > digits> Clock
Clock > Clear > digits> Start
Otherwise, it may be hard to help beyond this, since it;s been a long time since Toshiba made microwaves.
Mar 17, 2008 | Microwave Ovens
Microwave Ovens Logo
73 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
