Question about Samsung Refrigerators
Fridge light flasing but the fridge isn't cooling could it be the Fridge evaporator. This is a RS21DCSV Samsung Twin Cooler Fridge/freezer
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Hope this helps ??">
Posted on Sep 15, 2010
How to fix the rs 2555 refrigerator is not cooling, but the freezer is fine
1) Twin Cooling System
·The refrigerator and the freezer have two
evaporators.
Given this independent system, the
freezer and the refrigerator are cooled individually as
required and are, therefore, more efficient. Food
odor from the refrigerator does not affect food in the
freezer due to separate air flow circulation.
The Evaporator unit for the fridge may need servicing.
if you handy with tools you can fix it yourself the manual link is below
http://vdmeulen.net/handleiding/Samsung%20SR-S24%20FTBS/samsung%20rs2555sl%20service%20manual.pdf
Aug 16, 2014 | Refrigerators
I have a samsung RS21DCSV/X FRIDGE FREEZER.THE FREEZER WORKS PERFECTLY.BUT THE FRIDGE WILL ONLY COOL TO 13 DEGREES
Initially, pls check the:
  • thermostat and its setting for the fridge part;
  • check if the fan is spinning to draw cold air from the freezer towards the fridge portion;
  • check if any food stuff is blocking the fan/vent;
  • on instances where a large number food stuff has just been placed inside, it may take some time for the temp to go down;
  • see if you have a turbo cool and enable it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Refrigerators
Do the samsung twin cooling fridge freezer does it need gas??
hi . all fridge freezers need gas ? .. depends what wrong with yours .. checck out
samsung fridge freezer problems on youtube
some videos ....
and
Nov 10, 2010 | Refrigerators
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Fridge & Freezer not cooling
You will need to change the complete control pc board.
Mar 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Refrigerators Logo
390 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
