Question about Samsung 923NW 19" LCD Monitor
Samsung syncmaster 923nw stops backlight n detecting input signal after about few seconds
  • 6771 Answers
SOURCE: Samsung's LCD monitor SyncMaster 740N; backlight
There is a inverter transformer on the board that may be defective that generates the high voltage that drives the lamp, you may end up having to replace the whole inverter board to get it working again.
Posted on Jan 26, 2011
SOURCE: Samsung SyncMaster 740N - backlight dead
Power on monitor is on but faint back light
Posted on Feb 22, 2009
MNfisherman
  • 11896 Answers
SOURCE: 923nw samsung resolution problem
on ooptions screen, click box that says only show settings the monitor can handle. Then try changing the horizonal and vertical settings on monitor to match it up with your settings.
On your windows main screen, right click, then properties, then settings, check all the settings
Posted on Jul 09, 2009
benwabnick
  • 2404 Answers
SOURCE: samsung syncmaster 226BW no backlight
Look for any bulging capacitors, instead of a flat top they will look "pregnant".
If you see any of those then replace them with capacitors of the same UF rating and the voltage needs to be either the same or higher.
If you dont see any bulging capacitors or burnt parts, then its got be the LCD at that point thats not staying on and the cost to replace the LCD is as much if not more then to just get another monitor.
Posted on Aug 27, 2009
  • 732 Answers
SOURCE: Samsung SyncMaster 931 BF CCFL voltage only stays
Robbert_R_V, Have you visited YOUTUBE to search out and view some of the longer video clips of "LCD monitor disassembly" or "LCD monitor repair" or www.ccl-la.com/badcaps.htm site run by "buddymc" on fixya. Do that first!!! FYI !! Also try www.lcdparts.com for some additional info. Here is a hint of a similar TECHNOLOGY that you are dealing with. Have you seen the CURLIE-Q energy-efficent CFL light bulbs at the homecenter stores? They have what is called an ELECTRONIC BALLAST circuit called a CONVERTER! AC to AC. You have a ballast called an INVERTER. DC to AC 800v to 1200v to light-up your thin, straight, tubes hung on the backside of your LCD glass panel! If this info was of some help, please rate this response on fixya. Bye for now. 12fixlouie
Posted on Oct 27, 2009
What are the values of R815 R813 R818 Q804 D802 D804 for Samsung Syncmaster 923nw
http://archive.espec.ws/files/Samsung-SyncMaster-940N-LCD-Service-Manual.pdf
Nov 30, 2015 | Samsung Computers & Internet
Syncmaster 923nw. what are the values/identification of R815, R813, R818, Q804, D802, and D804?
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiH7_-jlPXOAhXKK48KHbtmDjoQFggeMAA&url=http%3A%2F%2Farchive.espec.ws%2Ffiles%2FSamsung-SyncMaster-940N-LCD-Service-Manual.pdf&usg=AFQjCNHkEUK4EwjpJBygL1GEaEPBMXMfyA
Check signal cable
This messsage is usually displayed when the Monitor is unable to detect any input signal this can be due to the faulty cables (VGA/HDMI). I suggest you to try to connect a different cable and check if the monitor works. If not then update your video drivers.
Sep 21, 2013 | Samsung SyncMaster 540N 15" LCD Monitor
How do I unlock the monitor, given that I have applied all the usual button pushing solutions bar 1?
If you see a picture but then it fades out after a few seconds then the issue is with the backlight power supply in your monitor, This could be a single component failure or more serious.
Mar 07, 2012 | Samsung SyncMaster P2250 22 inch LCD...
My Syncmaster 730mw keeps losing its picture afer a few seconds. No matter which input I use VGA, SCART, Component the picture comes up crystal clear and then flicks off after about 1 - 2 seconds! I can...
If you can make out a faint image then the fault is a backlight problem.
The fault could be an inverter board or the CCFL lamp/s
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 19, 2009 | Samsung SyncMaster 730MW 17" Flat Panel...
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Jul 09, 2009 | Samsung 923NW 19" LCD Monitor
N0 or Very little backlight on Samsung SyncMaster740 17" Monitor
back light is going bad. if you see a pinkish hue on the" checking signal" box on screen when it comes on. Should be white.
Feb 22, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
My samsung NW920 turns off after 1 min
If the blue LED ist blinking the monitor does not receive a video/sync signal. If the blue LED is on continuously and the display comes on for a few seconds and then goes dark or dim the backlight inverter may well be defective. The CCFL of the backlight needs several hundred volts to function.
Jan 11, 2009 | Samsung SyncMaster 920NW Monitor
Samsung 923NW 19" LCD Monitor Logo
281 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
