Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
My ice depenser is freezing up and the hole the ice goes through in the door
    Genius:
  • 1,122 Answers
BET IT'S A GE? YOUR SOLENOID THAT OPENS AND CLOSES THE ICE FLAP HAS RUSTED AND WILL NOT CLOSE ALL THE WAY LETTING AIR IN AND FREEZING THE CHUTE,CALL LOCAL REPAIRMAN.THANKS-MIKE
Posted on May 29, 2008
2 Suggested Answers
  • 74 Answers
SOURCE: the hole where ice comes throuh door freezing is freesing up
Flap closes under spring pressure and may not be closing fully causing ice/snow build up . Bend the spring to adjust the tension and lubricate with a little vaseline
Posted on Aug 28, 2008
When I press the ice depenser lever nothing happens no noise at all and no ice in glass.
Your dispenser is probably broke. You should get someone to come repair it for you. I have had something similar happen to me before.
Nov 27, 2014 | Refrigerators
Water leaking from the freezer unit.
The drain hole is probably frozen over. When it goes into defrost mode every 10 hours or so, the evaporator heater removes the ice from the evaporator. There is a drain hole under the evaporator with a hose attached that goes down to a pan by the compressor fan where it is evaporated so as to not leak water on the floor. When it freezes over the drain, the water fills the bottom of the freezer until it comes out the door. A common fix to prevent the drain from freezing over is to take a bare copper 14 or 12 gauge wire and put a couple turns around the evaporator heater and stick the other end into the drain. This heats the wire enough to keep water from freezing b over the drain hole.
Dec 09, 2013 | Jenn-Air JFC2089HE French Door...
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Water keeps freezing
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. This seems to happen on certain models. The door insulaton may have detereated. Some parts places have a heater to add on to prevent this. I have heard of taping additional insulation inside the door to prevent this.
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Maytag side by side refrigerator ice forms at the bottom of freez
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Jun 02, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice tray freezing
the water inlet valve may not be closing properly due to dirt or some mechanical problem in it. u can clean and try
Mar 10, 2009 | Kenmore 50522 / 50524 Side by Side...
The hole where ice comes throuh door freezing is freesing up
May 04, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Whirlpool ice dispenser not working
RECHECK THE CONNECTIONS AT THE UPPER DOOR HINGE WHERE THE ELECTRICAL WAS DISCONNECTED. MAKE SURE ALL THE PINS ARE STAYING IN THE PLUG WHEN YOU CONNECT THEM TOGETHER.
ALSO, BE SURE THE ICE BIN IS PROPERLY INSTALLED.
Apr 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice despenser door not opening
I had this problem. There is a piece of ice jammed in there that is blocking the door. try pouring some warm water into the hole from the inside and naking sure the path is clear.
Apr 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
109 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
