Question about Cycling
I have a Wireles Computer - an Echo(well) W1 I transfreed this across bikes, I now ned to transfer it to another bike and I seem to have lost the instructions, please help!! Brian It is basic set uipinstructions that i am seeking, Thankyou
I cant seem to get the timer to do anything on my excercise bike
The display (timer) needs to be connected to a sensor on the bike.
Make sure the display is plugged into a cable coming out of the bike.
If it's plugged in and still doesn't work, then contact the manufacturer.
It could be,
1. a bad display. (possibly a broken PCB connection)
2. a bad sensor inside of the bike. They typically use a Reed switch.
3. a broken connection in the cable or connector
4. the magnet fell out of its location.
You can get a replacement monitor from the manufacturer. If this doesn't solve the problem then it's either the sensor or the connection.
You can also place a continuity tester across the 2 contacts of the connector that plugs into the display. The continuity tester should flash when you pedal the bike.
Here's a link where you can purchase a continuity tester.
http://www.amazon.com/Extech-ET40-HD-Continuity-Tester/dp/B0025PK724
You can also pickup a continuity tester at any auto parts store.
Apr 27, 2015 | Body Sculpture Bc1510 Exercise Bike
Bike wont start, something with the Battery circuit or battery, we can push start the bike so the bike does run, I charged the battery and had the battery tested and it tests out fine, when I put in bike...
From your description, it sounds like a bad starter motor. That is provided all of the cables going from battery to relay, and relay to starter are not corroded or have poor connections. The relay is a weak point, so it may be damaged as well if the starter has been pulling too many amps.
Oct 13, 2013 | 2000 kawasaki ZRX 1100
MY SIGMA 1009 COMPUTER SCREEN SHOWS 0 MPH WHILE RIDING.SEEMS AS THOUGH IT IS NOT TRANSMITTING ANY INFO. SOMEDAYS IT WORKS PERFECTLY.
You want to make sure the magnet on the front wheel is being picked by the receiver on the fork. Sometimes that magnet attached to the spoke will move on the spoke so that it no longer closely passes by the receiver. If the magnet has been lost, check with you can check with your local bike shop for an extra.
Feb 26, 2011 | Sigma Sport BC 1009 STS Wireless Computer
Can you confirm what Reebok Edge excercise bike fault code E1 what this means as I have lost manual.
Same problem here! means that the motor is not sending a signal to the computer!? But that as far as ive got....................
Jan 11, 2011 | Reebok New York Giants Eli Manning Jersey
I HAVE TWICE POSTED MY PROBLEM ALRAEDY IN THE LAST COUPLE OF HOURS,. i HAVE A N ECHO Wireless Computer W1 - in changing this between bikes I have somehow manges to lose the setting up instructions, I am...
Go back to where you bought it and see if they have an extra set of directions. If, they don't maybe they can call the manufacturer of Echo. Or you neighborhood bike shop mechanic may know the numbers for your wheel size.
Aug 22, 2010 | Cycling
I HAVE A 250 SUZUKI ACROSS MOTOR BIKE. i need to
please buy a repair manual-they hav details of every part of bike
Jan 14, 2010 | Suzuki Rg 250 Motorcycles
Hi i have a echo-w1 wireless bicycle computer but lost manual to set up on another bike can you help
You can find the setup and installation manuals here. Just select the Echo-W1 / W2 from the list and download.
Jan 08, 2010 | Cycling
Have lost Echo W1 instructions. Can I get
Y've got the manual; send me an email to fortez@tin.it , so I can reply with a pdf enclosed
Sep 10, 2009 | Cycling
LOST POWER WHILE RIDING
It is likely that youve popped a fuse
The battery would have to be totalled to behave like that
But it sounds like the battery isnt being charged properly. Make sure the voltage across the batt terminals is at least 13.5v at tickover rising to no more than 15.5v at higher revs
Make sure the battery connections are TIGHT as well
Ride-Safe
Bike-Doc
Please mark this as helpful (if it has been!!)
Aug 14, 2009 | 2001 kawasaki ZX-6R Ninja
Cycling Logo
656 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
