Question about Epson Stylus Photo R220 InkJet Printer
Blinking both the ink botton ligths and the botton paper
My epson R220 are both blinking the ink LED and the paper LED when i turn on the..It is Fatal error?? I instal the ink system properly??what is the cause of it??
  • Anonymous May 13, 2008
    General error. See printer bla bla. Red light blinks but printer will not function. Makes a clicking noise.
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
Posted on May 06, 2008
When the green blinking both the ink botton ligths and the botton - cp_light_1.gif power light is off and the red cpblinking both the ink botton ligths and the botton - cp_light_4.gif class= paper and cp_light_4.gif ink lights flash, the print head is not able to move back and forth freely. Follow these steps to clear the paper path:
  1. Turn the printer off.
  2. Open the printer's cover.
  3. Gently remove any jammed paper or other obstructions from the paper path.
  4. Close the printer cover and turn the printer back on.
Posted on May 08, 2008
  • 158 Answers
Replace ink cartridge and see.
Posted on May 04, 2008
Hi, What says the EPSON printer monitor?
Maybe it's requiring service because the waste ink pad became full of ink if the software says that some parts of the printer are requiring service.
Epson 1440 printer repair
both the paper/ink buttons blinking in red simultaneously means fatal error. Use AP for figure the latest fatal error code. Btw, i have Service manual for 1400. Contact me at aicaxz(at)yahoo(dot)com
Jan 15, 2013 | Epson Stylus 1400 InkJet Photo Printer
Both red light keep blinking
You need to reset waste ink counter. Use SSC Utility or R220/R230 Adjusment program. Find the software at indoreset.blogspot.com.
May 27, 2009 | Generic Memory EPSON STYLUS PHOTO R220 w/...
Blinking Lights on Control Panel
this mean your printer need to be reset try holding down all 3 bottons for 5 sec if dont dont work let me no and i will send you the link to software that will
Dec 02, 2008 | Epson Stylus Photo R220 InkJet Printer
R220
what type of light? ink light or paper light?
if its on ink light it means one or more of the inks is empty, if its the paper light means paper is jammed.
try to turn off/on the printer then load again paper.
Sep 26, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r220
The printer may have an internal error or a hardware issue already.
Ink pads full usually indicates if all lights are flashing and an error msg would pop up in your computer screen "parts inside..."
Here's what you may want to try.
Just turn off the printer.
Checked for obstructions or any foreign objects inside the printer.
Try to check from inside the printer where the ink cart holder is, from where you load the paper and from where the paper comes out.
Jun 05, 2008 | Epson Stylus Photo R220 InkJet Printer
Repair manual for epson photo r220
Here is the link for your printers document and manual
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
pls dnt 4get to rate, thanks
Apr 20, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
This seems like you have two separate errors.
For the loss of ink problem, see my previous posts about under head cleaning. This should get you going again, but if not, there is another known issue which causes these machines to stoip printing. This problem stems from a manufacturing "feature" which results in a broken pipe. To get a fix for this you should contact http://www.TheServiceManualShop.com and ask about there countermeasure for loss of ink in the Photo R series
The second error with the flashing lights depends on the sequence in which they flash. If the power light is off and the Ink and Paper lights flash half second on and half second off but alternating, then you have a maintenance request. This is easy to sort with yet another kit from The Service Manual Shop (R220 rescue kit)
If the sequence is Power light off but ink and paper flashing simultaneously then you have a fatal error. These are somewhat harder to attempt to fix and may require specialist knowledge and big parts that put the machine beyond economical repair.
Having said that, it can be worth taking the machine apart and removing the ASF assembly then reassembling as sometimes the feed mechanism ties itself in a knot and throws up a scary error.
Hope this helps a little
Oct 13, 2007 | Epson Stylus Photo R220 InkJet Printer
Both Ink & Paper lights flashing!
Hi JayBirde Do the lights flash Together (not alternate) and is it a quick flash (0.1 second on 0.1 second off)? If so, check the Status Monitor for a message. If it says Fatal Error or General Error, then you have a task on your hands! If the lights flash alternate (0.5 second on 0.5 second off) then this indicates a maintenence error and the status monitor should say parts inside your printer have reached the end of their life - or something similar. This much easier to fix with an R220 Rescue Kit from www.TheServiceManualShop.com - use their search to look for R220 Rescue. If you can't find it, just drop them a line and they will create one for you. Delivery is via instant download so no waiting around to get your machine fixed. If you have a general or Fatal error it means the printers head can not move using the norm,al amount of force - i.e. something is in the way. You can check a few things: Ensure their is nothing in the path of the print head - paper, foam from the pad, head lock not retracting, toy soldier on manouvers in the mechanism etc Chech the encoder strip ( a grey-ish looking plastic strip, near the drive belt for the print head) is clean and attached. Check the lid for the ink cart cover is full closed.
Oct 28, 2006 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
479 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
