Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Changed the tire on my craftman lawn mower and now it will not drive
    Brigadier General:
  • 3,911 Answers
There is a key keeping the wheel and axle in sync. make sure this did not fall to the ground when you removed the wheel. fits in the slot on axle and wheel. if you lost it you can buy another at a small engine parts store. another possible problem is that you slid the wheel on backwards and it is rubbing against the mower frame.
Posted on Aug 22, 2010
How do i change a drive belt on a craftman series 700 rear wheel drive lawnmore
Remove and save any bolts holding the idler pulley to create slack.
Replace the belt. Put the bolts back in. Check the tension and alignment.
Put mower back into service.
Nov 18, 2015 | Garden
I have a craftman rotary lawn mower
Check the drive belt as it may be broken or most often they get out of adjustment, too loose and fall off of the drive pulley.
Sep 19, 2014 | Garden
Will a shaft from a 14 yr old craftman lawn mower fit on a 2 year old craftman
need to have model numbers from both engines with spec numbers as well but most likely no
Jun 21, 2012 | Garden
Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Sep 11, 2009 | Poulan Pro " Pro" Self Propelled Mower
Craftman 6.6 self propelled mower blowing oil between the upper &
The Breather or Dip Stick Gasket at Engine. It you had the mower turned on its side befor problem, its coming out of the Muffler. This will go away but check your oil level.
Sep 08, 2009 | Craftsman Garden
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
