My four computers do not work on the WRT54G. Since it was set up, I have one computer reliably able to get online via the router and Hughes Broadband Satellite service, which I put in to use the router. Two others of my computers are sporadically able to get online. But at no time have I been able to get more than two computers online. All these three computer are wired into the ports, two of which are also capable of wifi to connect that way. The 3rd other computer is unable to get online, though I bought a Lincsys WRE54G range extender for it to do so. I have configured and re-configured my computer settings so very often, and tried very often to get the default settings on the router to work. I inv itable end up with a notation on the screen of eacxh of the computers when rejected that the IP address is anablew to be accessed. What on earth is happening? How do I get this thing to work consistently? As soon as I added the range extender I got problems with the one computer that had been reliably online, and has since I unplugged the range extender. I have reset the rourter very many times to try to make it
  • FThorne Jun 06, 2008
    Thank you all for your recommendations.
    In the process I have successfully got two of my computers consistently on line, even simultaneously.
    But in the process, the network configuring of my main laptop has gotten messed up, which was the only one originally working consistently!
    When I run the Linksys router setup wizard program it quits after checking the router and the computer, continually cycling to demand the password, then checkig again, a long and tedious process because there is no further progress. so the thing is somehow stuck!
    How can I clean out the network programs bin to start all over with this computer.
    I cannot find the program in the program list, so cannot remove the Linksys setup that way.
    How do I do it?
    Thank you.
    The fourth computer unable to be gotton online I've just forgotten about that one for the time being.
    Fred Thorne
  • 13,433 Answers
This may be caused by what the other expers have said about DHCP servers.
This may also be a problem of limited outside IP addresses incase this is a Bridged type connection.
First we should try static ip settings.
on your computers network settings start with setting the ipaddress to
192.168.1.5
then for the 2nd computer
192.168.1.6
for the 3rd computer
192.168.1.7
for the 4th computer
192.168.1.8
All subnets are default 255.255.255.0
Default gateway is 192.168.1.1 - the address of the wireless router or the satellite box
settings in the wlan router need to be changed to manual ipadress 192.168.1.1 - 255.255.255.0
DHCP off
Posted on Jun 06, 2008
    Brigadier General:
  • 6,966 Answers
Have you tried static IP addresses on all of your PCs even if DHCP is enabled in the router?
Additionally, pls try with the WEP, WPA or MAC Filter off/disabled.
Alternately, on the units that are WiFi capable, pls try configuring the Wireless LAN Properties Advanced tab to use "ANY" or your SSID.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information on how to setup/configurre static IP adds..
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
  • Louie  Role
    Louie Role May 04, 2008
    Hi FThorne,
    with the indulgence of sweet_rascal...
    If your Hughes Broadband Satellite service is anything similar to Gilat Satellite Network, then the problem is both the satellite modem and the LinkSys WRT54G are operating with their DHCP function ON. This is not acceptable in a closed loop home network. A network can not have more than one DHCP server, so it is either the Hughes Broadband Satellite or the LinkSys WRT54G or not to use either or both, hence my initial suggestion of using static IP adds. Alternately, you can disable either one's DHCP. However since you have wireless, perhaps it is to your advantage to retain the DHCP feature of the LinkSys and disable that of the Hughes.
  • Louie  Role
    Louie Role Jun 06, 2008
    and hi again FThorne,
    Still having issues? Have you tried disabling the DHCP of the Hughes Broadband Satellite, use static IP on the WAN side of the LinkSys as well as using the 192.168.1.XX on all of your computers?
    Guru:
  • 1,894 Answers
As far as i understand u want to make a LAN between those 4 systems right?
  • dewan nafees ahmed May 04, 2008
    ok this is my view..
    as far as i think.. u need not strain much in connecting all the systems online.. just connect the online system to the router and then connect other systems to the router. there is no need of doing a configuration also... because this how we use 3 computers at our house..
    also u said one system is not at all connecting.. check if u r using the proper "straight" cable to connect it..
    also try all the solutions given by benimur.. u may get fixed at some point..
    good luck..
    have a good day..
I cannot install my router
The WRT54G give a high-speed Internet connection, via Ethernet, with up to four computers.Setting up the router consists of some steps.Read more
Aug 23, 2012 | Linksys Wireless-G WRT54G Router
I can not make my D Link DIR-615 work with Hughes HN9000 modem. The D Link is located at the PC and Hughes modem location so I can wire 1 PC but need the laptop to connect wireless. I tried both an...
If you connect Modem to your laptop, can you go online?
If you are able to go online like that then log onto www.hnetworking.com and we can take the remote access of your computer and try help you out.
Feb 28, 2011 | D-Link DIR-615 Wireless Router
I lost my cd to my linksys wireless router m#.WRT54G ....how can I get the router to work???
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 26, 2010 | Linksys WRT54G Wireless-G Broadband Router...
Getting ip address, but cannot connect to internet through router. I am connected via an ethernet cord. No problems with modem.
Aug 20, 2010 | Linksys Wireless-G WRT54G Router
Cannot connect to internet via router WRT 54GS
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
then you need to connect the computer to the router and the modem to the router.
May 08, 2010 | Linksys Wireless-G WRT54G Router
Taking forever to configure computer on reinstallation of wrt54g
Mar 14, 2010 | Linksys Wireless-G WRT54G Router
Router not hooked up properly??
Mar 10, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
WRT54G v5.cannot access the internet when wired through the router.router does not communicate. do not have software. I can access the internet via modem only. basically the router is brain dead. Is their...
Are you trying to install the router.
WRT54G v5 router has firmware issue. First you will need to upgrade the firmware of the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online
through the modem.
modem
Then you need to connect the computer to the router
ad the modem to the router.
Click Here for step by step by instructions
Jan 21, 2010 | Linksys Wireless-G WRT54G Router
Does a satellite internet network require a special wireless router or will a DSL wireless router work? (Huges satellite)
They will provide you connection on their satallite modem. You can use any wireless router of your choice with the same.
Regards
Sammy
Aug 27, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
