Question about Car Audio & Video
Lmy jvc double din dvd player has please reset on the screen how do i fix it
  • 3 Answers
SOURCE: JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Posted on Sep 01, 2007
HW_Dude
  • 87 Answers
SOURCE: won't record...says din lock
I'd say you have the digital input selected. The player does not see a digital signal and gives such message.
Select the analog input and you should be able to record.
Hope this helps.
Posted on Jan 13, 2009
dunnbiker
  • 8546 Answers
SOURCE: digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Posted on Jan 31, 2010
SOURCE: User Manual for JVC KW AVX 826
www.jvc.co.nz/assets/pdf-manual/KW-AVX826.pdf
Posted on Aug 04, 2010
SOURCE: I have a DP video DZP903 in dash dvd player. The
dp video face plate dzp903
Posted on Aug 05, 2010
Parking brake switch wire on a power acoustik double din
this use to be simple for most units and yes it would work, however, manufactures became wise to this idea and placed a relay inside the unit that must be reset to prevent us WISEGUYS from doing so, but i do not know if this is the case with yours, if it is then you can run a toggle switch between the unit and the ground in order to reset this relay as needed with a flip of the switch
Feb 21, 2013 | Power Acoustik PTID-6250 6.2" DOUBLE-DIN...
Need a replacement faceplate for a JVC KW-AVX730
You can find replacement faceplate on amazon, take a look here: Amazon com JVC KW. Wish you best of luck. Joseph
Jul 17, 2012 | JVC KW-AVX730 In-Dash Double DIN 7"...
Hi ive got an 12VCITY MA-7004 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i
hi, i bought <a href="http://www.12vcity.com/wholesale-car-electronics-car-dvd-2-din-car-dvd/13-car-double-din-dvd-player-buy-car-double-din-dvd-player-ma-dvd7004.html">12VCITY MA-7004</a> on 12VCITY official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.I think maybe you have connect the wrong wire and have bum out the built in amp.
Jan 11, 2012 | Car Audio & Video
LMy JVC CD player reads PROTECT across the screen even after resetting the cd player it still reads PROTECT, I'm so lost now because I don't have amps or anything attached just regular car...
Try checking your speakers and speaker wires for shorts and/or grounds. Make sure none of your speaker wires have any bare spots. If your speakers and speaker wires are fine, you may have a bad internal output ic inside of the deck.
Jul 14, 2011 | JVC AM FM CD DET FACE CAR STEREO
I for got my password for my kenwood double din dnx7140 and i dont have a manuel for it wife got it for me used
You can download the manual at
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Consumer/Manuals/dnx7140.pdf
Dec 15, 2010 | Kenwood Excelon DDX-7015 Double Din Car...
Mar 03, 2010 | JVC KW-AVX810 Car DVD Player
Dvd player wont show picture
To fix this issue on the back of the double din touch screen#uv8020, splice the pink wire, and splice into the (black) ground wire connecting them together. This will enable you to watch dvd;s whie driving.
Jan 22, 2009 | Phase Linear UDV9010 Car DVD Player
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
