Question about Dishwashers
Have a fisher paykel dw920 and f1 fault displays, apparently a flooding switch has been activated. How do I fix this problem ?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are right
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 22, 2010
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Eletronic oanel displays F1
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Jun 21, 2010 | Fisher and Paykel DS603SS Stainless Steel...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
I have a single draw Fisher and Paykel dishwasher. I stupidly put washing up liquid in the dishwasher which resulted in a F1 problem. Water started leaking under the draw and onto my floor. I turned the...
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Apr 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 fault
F1 code would mean the flood switch is activated.
In Nautilus people have found this to be caused by a faulty door seal.
Water seeps under the diswasher base panel and finally the flood switch (a protection) activates.
The solution is to replace door seal after drying out under the base panel.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel diswasher f1 fault code
f1 fault code means the flood switch is activated. There is moisture at th e base of your dishwasher.
Dec 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
