Question about HP Scanjet 3400c Flatbed Scanner
Only use .jpg extension for scanned documents.
What kind of software I need to put scanned documents under .dbf? This scanner only use .jpg files extension.
  • Anonymous May 27, 2008
    I NED DRIVERS
DRIVERS
Posted on May 27, 2008
What is file format not supported
A file extension, also called a filename extension, is the suffix at the end of a filename, which indicates what kind of file it is. For example, you can tell that the file "computer.jpg" is a JPEG image file, based on the ".jpg" file extension. Similarly, you can tell that "readme.txt" is a text document and "document.docx" is a Microsoft Word document. Knowing what extensions common file types use can be helpful.
Jun 12, 2012 | Computers & Internet
Tip
Scan multi-paged document and create a single PDF document
1. You need to install a PDF printer driver on your computer first.
There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
To download CutePDF printer driver (freeware) click on this link :-
http://www.cutepdf.com/
2. Using your computer SCAN the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scaning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document if you require but not needed.
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
on Jul 07, 2011 | Computers & Internet
How to scan multiple pages in one pdf in hp 5300c scanner
To do this will take a few steps.
1. You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
2. Scan the first page then click on File - Save the image as a jpg file Eg. image1.jpg
5. Close the scanner when finished scanning.
7. Save the Word document (not necessary).
Jul 07, 2011 | HP ScanJet 5300C Flatbed Scanner
I need to copy a word document however when I scan it, it makes it into a jpg document. What can do I fix this in order to be able to edit and save the scanned document as a word document?
Make sure you installed the full software suite for your scanner. Scanners do scan to image files but should come bundled with Optical Character Recognition (OCR) software. Select the OCR option in your scanner settings and it will convert your scans to an editable format. Take note, OCR software is only as good as the scan, and the content on the paper, so it might make some mistakes, in which you will have to manually fix in Word etc "proofing"...
Regards, Chris
Jun 29, 2011 | Fujitsu fi-6130 Flatbed Scanner
I received a file from someone who scanned a document and it was saved in a .nrf type file extension. She sent it to me an I cannot figure out how to open it. Can you help
you will have to contact them and ask them to save the file as a image file instead, the only way , that i know how to open that filetype is by using NEC's scanner software, which created it
Apr 11, 2011 | NEC Office Equipment & Supplies
Put scanned document on my computer to print afterwards if necessary and read on my computer
I am unclear on your problem but in general..you use the scanning software that came with the scanner scan the document and save the scanned file to your computer as a pdf file for documents or tiff or jpg for photos, (you set the type of file you want to save with the software options)
To print afterwards open the pdf with acrobat and print it
Did that answer your question?.
Mar 07, 2011 | HP Scanjet 5590 Flatbed Scanner
Have previously used scan feature on the psc 1510 with no problems. Now when I scan a half page document I get a file size of 8 to 10 MB depending on resolution (200 or 300). I have tried pdf, jpg, etc...
kindly reinstall the the scanner software.Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components
Have a nice day and do not forget to rate please...!
Dec 24, 2010 | HP PSC 1510 All-In-One InkJet Printer
When I save a scanned document you increase the file size. Please. Thanks.
Document size can be set before you scan.
Your scanner software should give you options for type of document and resolution settings. If your documents are to large, set resolution lower.
Example, Black and white or greyscale scans are much smaller in size than color documents.
Saving files as jpg will compress the file for storage.
If you have an image editing program you can decrease the size of the file after the scan.
Dec 09, 2009 | Kodak Office Equipment & Supplies
Huge HP scanner files
could be you are scanning pictures of documents and not doing OCR..Optical Character Recognition
Jul 23, 2009 | Konica Minolta magicolor 2430 DL Laser...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Scanjet 3400c Flatbed Scanner Logo
Ben Johnson
