Question about Acer TravelMate 4220AWLMi Notebook
My laptop has problem, it is not indicates charging light and also not charging so it can't start should i replace battery ? how can i run my laptop on dirict pluged in plz, give me idea
  • 400 Answers
Well It doesn't seem to me the problem of battry so replacing it is not a gud choice if you want to confirm that then take out the battry off your laptop Plug in the power pin and press the power button see if it start on direct pluging if it does then it must be your battry which requires a replacement and if does not than you power plugin socket needs to be reparied. Hopefully this would help...
Posted on Aug 22, 2010
Testimonial: "thanx"
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
No light indicator charging battery adapter
If the computer starts with the power charger plugged in, then replace the battery.
good luck
Sep 20, 2013 | Dell Vostro 1014 Notebook
Laptop screen flickering when battery charging
The power supply adapter may not be delivering enough power when you run it and trying to charge the battery at the same time. The only way to find out is sub another power supply.
Jun 19, 2012 | Toshiba (M305-S4910) PC Notebook
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
Battery problem
its a battery problem try exchange it
please vote
Jul 25, 2009 | Dell Inspiron 2200 PC Notebook
Dell inspiron b130 power problem
try running with battery out it should still work as long as it is pluged to a/c
Feb 18, 2009 | Dell Inspiron B130 Notebook
Blinking battery light
Green is charged, Orange is Charging and Red indicates a low charge or a possible weak or defective battery. All modern batteries are controlled by a microprocessor that monitors the health of the cells. Even if the battery is holding a workable charge, it can still be deemed "bad"
If the battery is fairly new you might get a replacement from Dell, if its a year or more old, it could be dying an early but not abnormal death. If more than 1.5 years old, be sure to check the Dell battery recall list as some of these are recalled and you'll get a free battery replacement if its on the list!
-Good luck
Jan 05, 2009 | Dell Inspiron 9300 Notebook
Acer laptop
If the machine works properly with no problems, it's probably the battery light, indicating that the battery is no longer working properly, ie.. not charging, not holding a charge, not charging completely, etc... and needs replacing. Somewhere right around the light there should be an icon or symbol, I'm betting a little battery icon.
Jul 08, 2008 | Acer Aspire 3003WLCi Notebook
Compaq laptop Evo N410c Battery charging
Hi
First remove the battery and run only on the adapter... If it works fine then there is no problem with adapter...... Charge the battery continuously for 4 hours without seeing the percentage of charging and remove the adapter..... If the laptop runs on battery for 45 mins then it might be the problem with drivers..... Go to device manager and reinstall the drivers if it is less than 45 mins.... Reinstall the drivers either ways...... If still the problem persists.... Go to HP.com and and select software and driver downloads and give the product number.... select the OS... Select HP battery check.... Download the file (sp32299.exe) and click save.... Save file onto the desktop and close the site..... Run the exe file.... If it passes the battery is fine... If fails replace the battery....
The steps might be longer..... But i can assure that it will work
Oct 22, 2007 | HP Compaq Evo n610c Notebook
Acer TravelMate 4220AWLMi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
