I have two jbl lsr6325p studio monitors. I'm not getting any sound out of the main part of the speakers. Only high-end sound is coming out.
  • 1,689 Answers
It is possible that the main drivers are damaged, or that the internal crossovers are damaged, or there may be internal fuses that are blown. If these are using internal power amps, there may be a fault in the power amp sections.
Jerry G.
Posted on May 04, 2008
My JBL 510 high end pops intermittently
Damaged component/s at its main power amplifier stage circuit. Leaky capacitor/s can cause this fault, and locating the exact one is a skilled work indeed. It will be best to contact any service technician. This is not a user repairable fault. If you wish to get some details, visit the site linked here.
Electro help
Nov 15, 2014 | JBL EON 510 EON510 Powered PA Speaker
Very little output from tweeters Samson Resolv A6
same issue here, my 6 inch woofer is good but the tweeter is not producing sound, i opened the box myself, theres not signal going to my tweeter, how can i check to see if its a wiring or other issues to diagnose myself? heres some pics
Aug 10, 2012 | Audio Players & Recorders
Speaker monitor will not power up
Most likely bad electrolitic capacitors from it sitting for a long time
Feb 10, 2012 | JBL LSR 2328P 8" Bi-Amplified Powered...
My speaker sounds muffled. Its alot of low end put not that much high. All my eqs are adjusted fine, and when i plug the same wire into my Mackie, NO PROBLEMS. It's definetly the speaker
well it sounds like you know what the problem is already, the first thing you need to determine is if the fuze is blown, jbl's are expensive speakers and usually there is an internal and sometime an external fuze, sometimes the midrange and tweeters are fuzed sepeataly. I'm ont familiar with that particular model, but if it not a fuze then most likely you have overloaded the high end speakers and they may have blown out, the high freqency drivers and not cheap and if they are new and under warranty you might have a chance to get new tweeters/horns free but if it is your fault e.g. too much power going in, then you will have to pay for them. You can get replacemdent JBL or other good speakers at they are out of Cleveland Ohio and you can call them when you get their number off the website..
Mar 20, 2011 | JBL PRX512M Speaker
I have a set of JBL control one speakers and the foam suspention has decintergrated can i get it repaird
You need to have the speakers re-coned. Unless they are really really good speakers this will cost you almost as much as new ones. A JBL authorized repair facility should be your next call. Replacing them is probably the answer
Jan 20, 2011 | JBL Control 2P Monitor Studio Active
I have a pair of jbl pxr 515 and both of them have a problem in which the lower end cuts still getting the high end.....i have to push the input button a few times and they come back on
moz-screenshot-5.pngmoz-screenshot-6.pngmoz-screenshot-7.pngmoz-screenshot-8.pngmoz-screenshot-9.pngHi, problem can be solved..might not be able to really give you full help, cause the details you gave is not a 100% detail for me to give you a 100% answer.
I will give you possible solutions to the problems .
When a speaker does not give you low ends, it might be because the crossover controlling the output of the speaker(low).You will need to open up the speaker and test the fuse inside if speaker..
Also it depends on what the speaker is connected to, is it's an EQ or a Mixer, You can cut down high frequency from both the EG and Mixer.. i guess that will do..
And make sure you when ever you connect the speaker you use a mono jack or a speakon plug for good quality sound.
Hope it helped..
Feel free to pass on your comment ..
Thanks for using fixya...
Jan 10, 2011 | JBL PRX515 Speaker
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here:
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
Jbl e80 no sound coming from tweeter
Sound like the tweeter is blown, take to local jbl agent for service.
Sep 16, 2009 | JBL Northridge E80 (Single) Main / Stereo...
171 people viewed this question
