Question about Goodman CLQ36AR49 Air Conditioner
It's a brand new unit but it blows air so hard and makes so much noise. Can the flow the adjusted down?
    President:
  • 2,468 Answers
Is the fan outside too noisy,if so there is no way to change the speed of this fan,the blower motor in the furnace can be adjusted,either by adjusting the centrifugal pulley on the motor shaft or electrically or installing a different squirrel cage fan on the furnace blower
Posted on Aug 22, 2010
Testimonial: "Can I adjust the blower motor easily?"
  • scottmcdaddy Aug 26, 2010
    sounds like the unit is too big for the ducts.
3 ton heat pump with piston in air handler. After unit shuts down it makes loud fluid flow noise for about 2 minutes
adding a tvx will not help. the sound you here is the pressure equalizing and that has got to happen for the compressor to start again the next time. A tvx will give you a higher efficiency because it can adjust to changing temperature conditions. Only way i know to quiet the noise is to try to insulate the lines better.
Sep 14, 2014 | Goodman GSH130301 Heat Pump, 3 Ton, 13...
How to adjust air flow on jacuzzi vectra II
Yes you can, there should be air induction knobs: Adjusts air flow from off to maximum.
Turn it down.
It looks like this...
Jun 15, 2014 | Jacuzzi Pool & Spa
THE rEFRIGERATOR IS NOT COOLING OR FREEZING AND IT MAKES NOISE WITH THE RELAYS WHERE THEY ARE CLICKING ON AND OFF. dO NOT HEAR A FAN BLOWING OR THE UNIT MAKING COOL AIR.
I did not see a model or brand on your request but i'm going to guess that ist a G E and the clicking rellays are a common noise when the program board has failed . the unit will shut down / as the board controls the compresor and fans / heater //defrost cycles . if more help is needed i need the brand and model # .. hope this helped mm feed back pls and thanks for ysing fix ya .
Dec 11, 2010 | Refrigerators
THe a/c has very weak flow of air blowing even with the fan on high. My last carrier had a high volume of air coming out of the vents which was adjusted by the installer as I desire room by room. This...
It sounds like you got shafted and the guy installed a smaller air handler unit with a smaller motor to try to make more of a profit...
The problem is getting an unbiased opinion from someone who knows their stuff...sad to say but stuff like this happens all the time...
Here are a couple of tips that I wrote that may help you...
What Size Air Conditioner Do You Need?
http://www.fixya.com/support/r3636709-size_air_conditioner_need
Heating and Air Conditioning Scams
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
heatman101
Jul 23, 2010 | Carrier Heating & Cooling
The front air isn't blowing out as hard and the back a/c blowing out but blows out hot air! what's is the number one reason for this problem?
The number one reason for hot air out the back could be low freon or bad blend door to the rear, and not blowing hard out the front could be a block in the evaporator core. the core is like a small radiator that freon flows through and air is blown through it to make cold air sometimes if they leak it blocks the fins which slows down the air flow.
Jul 09, 2010 | 1998 Chevrolet Suburban
Wall unit will not blow hard at high speed
try to clean your filters and adjust your setting on the remote
Jun 06, 2010 | Carrier 36KCARMS Air Conditioner
AC on but nothing coming through vents
the therostats adjust a damper to open air flow . it could be a damper motor problem. or it could be the ajustment of the tstats. turn the up stairs up then go to down stairs turn it down. then see if the air is flowing. i hop this helps
Apr 15, 2010 | Ruud UAKA037 Air Conditioner
Just installed a 24000 BtU Art Cool deluxe type 1 unit in our room. It makes very disturbing "toctoc" noises all night apparently off the plastic case. The noises start when the condenser turns on and off...
it sounds like the noise you are describing may be coming from the vanes in the unit. if you adjust the vanes to a fixed position (from the remote) instead of a sweeping motion does the noise stop?
Oct 12, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
Sep 08, 2009 | Kenmore 75085 Air Conditioner
Air conditioning fan makes loud noise the faster you ru it.
Concerning your broken vent -- this can be caused by a broken linkage or a malfunctioning servo motor as well. these vent have air ducts the sway back and forth to adjust the dual air flow function. if the servo o linkages are malfunctioning or not connected for some reason, it will not allow total control of the air flow and temperature range. Now, if you have a combination of a flow error and temperature error as well, thai can be caused by a combination of the two.
In this case, you will need to inspect the linkages as well as the servo motor function as well. in addition, i would test the air temp sensors for there operational value. they control the temp when you adjust the coll or hot function.
Concerning the Loud noise coming from the blower fan---
This issue can be caused by a misalignment within the blower housing or, it can also be caused by some minor damage within the motor itself, causing it to rotate in a erratic manner, in return, forcing it to rub against the housing itself. the best solution here is to extract this blower fan housing and inspect for lose fan propeller and motor stability. replace parts accordingly.
PLease rate and have a great day:)
Apr 22, 2009 | 2004 Chevrolet Tahoe
Goodman CLQ36AR49 Air Conditioner Logo
200 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
