HAVE A DIMPLEX PORTABLE AIR-CON HAD IT FOR 6 MONTHS . LATEY WHEN YOU TURN IT ON AFTER 5 MINS IT BEEPS AND THE CODE E7 KEEPS FLASHING. CAN NOT FIND THE MANUAL SO DONT KNOW WHAT IT MEANS..PLEASE HELP
The E7 message indicates that the unit is full of water and needs to be drained. The drain plug is on the back of the machine towards the bottom on the right as you face the back of the machine.
You can empty the unit by pulling out the black stopper and tilting the air conditioner slightly to drain. Make sure you do it over a container or outside though, there's quite a bit of liquid.
To replace your instruction manual, you can find a pdf version of it here:
http://www.glendimplexdealer.com.au/Resource1049853HJDUFOS023X/Owners%20Manuals/Cooling/Instruction%20Manuals/IM%20for%20Portable%20Air%20Conditioners/Instruction%20Manual%20for%20PAC%2010-6-09.pdf
Posted on Jan 29, 2011
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Hi I HAVE A DIMPLEX AIR-CON It was already here when I moved into this house but lately after it been for on about 5 mins it stops and it display a code of P2. I dont know how to get hold of a manual...
If your model is a portable AC unit, the P2 indicates that water needs to be drained from the tank.
Turn the unit OFF and unplug it, before draining the water from the lower tank into a shallow sided pan capable of holding at least 1 quart of water. Once it has completely drained, reinsert the drain plug, plug the unit in and turn it ON. The P2 Error Code should have disappeared. If not, press the ON/OFF button twice.
I hope this helped you.
Jul 15, 2011 | Heating & Cooling
The timer light and the turbo light flashes, plus when I turn the air con on it will turn of 5-10 mins later and the lights will flash
your air con has defect and the sequence of flashing lights are tell us whats the problem. If you have electrical s knowledge we can try to resolve it online, if not is better to call a specialist.
Feb 27, 2011 | Samsung Heating & Cooling
I have a portable air conditioner from dimplex, dac15hc, it cools when 1st turned on then aprox 1-2 min later i hear the compressor turn off, the air coming out gets warmer until a code of ES is shown on...
E5 Outdoor activation of compressor over heatprotection or motor lock. Check fan motor mechanism is locked. Replace fan motor.If compressor getting high amps, replace running capacitor and check. If still problem, replace compressor. Thanks, helpful.
Feb 01, 2011 | Heating & Cooling
Anyone have access to a dimplex DAC15006RC portable air con manual?
You can download from:
www.dimplex.de/en/downloads/installation-instructions.html
Helpful?
Dec 26, 2010 | Heating & Cooling
Air con switches off after running for 15 mins
its going into a fault mode the fault is displayed by how the light is flashing. your manuel should have a fault code chart in it.
Jan 25, 2009 | Amcor PLM16000-E Plasma Series Portable...
Instruction Manual
I had the same problem. If you are in Australia, the Dimplex Customer Service number is 1300 6739 033. I phoned and they are mailing me the instructions. Maybe don't say you bought the machine at a garage sale.
If you are not in Australia, try the way I did to get your local customer service number - Google the product number and go to the Dimplex website, and there should be a "Contact Us' button with a phone number or mailing address.
Pat
Jun 21, 2008 | Heating & Cooling
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Heating & Cooling Logo
350 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
