The door wont open!! It has washed and drained but the door is stuck!! HELP
  • Washing Mach... Master
  • 3,361 Answers
What is the model number?
Posted on Aug 22, 2010
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
Problem with Hotpoint Washing Machines Samsung
ND -not draining. There could be something is stuck in the drain pump or one of the hoses connected to it( normally a coin is stuck in the L-shapped plastic connector to the drain hose)if the system is clear,then I would replace the drain pump.
Nov 02, 2013 | Samsung Washing Machines
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Hi, i have a hotpoint wf640 washing machine and i cant open the door.it seems like the catch has gone on the interlocking door as ive tried to push the door in but still no go. Is this something i can fix...
if there is water in the drum it wont open, so you need to drop the drain hose low to gravity drain....then the door should open. sometimes this fault is due to a broken door catch utube is quite good for fitting help.
Jan 08, 2018 | Hotpoint First Edition FEW12 Front Load...
Hi the machine wont drain and door wont open
this is usually a drain pump tha has something stuck in it and will not allow the water to drain out.use a shop vac and put it on the end of the drain hose to drain any left over wat the check th pump for a foreign object and remove this should solve your problem.
Sep 16, 2009 | Asko W6021 Front Load Washer
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Door wont open
The door switch could have stuck closed. there is a way to open it up manually.
if you can just access the water pump filter cover, and at the back part of the door switch you will find a plastic ring attached to the door switch, pull it down to open the door.
drain first the water if there is water left in the unit by slowly opening the water drain filter cover and drain the water slowly.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Washing Machines
Cant drain and cant open the door
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Jun 26, 2008 | Creda W100FW Front Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
