The internet is working on my desktop and i ahve a belkin iinet white box for our wireless but having trouble getting a connection for my laptop.. any quick options on getting it fixed.?
    Brigadier General:
  • 6,966 Answers
Have you tried static IP address on the laptop?
Additionally, pls try with the WEP, WPA or MAC Filter off/disabled on your router.
Alternately, on the laptop, pls try configuring the Wireless LAN Properties Advanced tab to use "ANY" or your SSID.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information on hot to set static IP adds..
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
I have 2 computers - a desktop without wireless and a new laptop with wireless. I want to connect the Belkin N150 basic wireless router to both these computers. I have introduced a "wired"...
WIRELESS SECURITY ISSUES
UNINSTALL THE BELKIN ROUTER MANAGER FROM THE LAPTOP
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP ( WPA WILL NOT WORK )
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 21, 2010 | Belkin Basic Wireless Router
Laptop stopped connecting via wifi to home network.
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 31, 2009 | Belkin (F5D7231-4) Wireless Router
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
My network connecton does not work when I connect the wireless laptop I cannot get Internet Explorer connection but if I disconnect the Bilkin I have no problem with my desktop
You are splitting your bandwidth, which is apparently insufficient to run the Belkin and your desktop. I am betting that you are connecting the Belkin to the ethernet in your Desktop, rather than connecting the Belkin to your modem and then connecting the desktop to your Belkin.
Try that if I am right.
Apr 11, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin F5D7231-4 and ADSL2+
I dont know...
however I would run ipconfig command on your PC. Make sure the default gateway corresponds to your router`s IP (if you indeeed have it conected to it)
And also make sure that your modem is set in Bridging mode and your router in PPPoE a
and the appropiate password input into it.
rgds
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
Hi, I have a desktop and a wireless router. The desktop was connected to the internet via a Belkin USB wireless adaptor but it has suddenly stopped and does not pick up any signal. I have uninstalled and...
Belkin products are notorious for breaking down at a high rate. If you wanted to rule out your computer as the culprit, you could install the belking adapter on your laptop (disable the built-in one) and see if it still works. I would also suggest going here:
http://www.belkin.com/support/
and typing in your product model # and downloading the latest firmware/software for it. As always, restart your computer.
Jun 10, 2008 | Belkin Computers & Internet
I have a belkin n wireless router keeps freezing
First step of solution would be performing Reset. Press and hold the reset button about 30 seconds and release. Check again. If you need customized settings just type 192.168.2.1 in your browser and get into settings.
If issue persist please post for further troubleshooting.
Good Luck
Jan 24, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
David Payne
David Payne
