Question about Neff H5470 Microwave Oven
B7740.... neff 900w microwave - no signes of power. Would like to check the internal fuse. How do I access it?
SOURCE: russell hobs microwave oven
I am a recently retired appliance engineer of 20 years, microwaves are not normally things worked on yourself, i would be reluctant to help normally but yes there is an internal fuse ( a special quick blow type )just inside where the wire enters the cabinet on a small circuit board, if a replacement is needed it must be exact match bought from an electronic shop, microwaves are dangerous they store powerful electric and can still shock after removing the plug, if the replacement fuse blows, there is a fault elsewhere, and i do not recommend further self repair, work with safety
Posted on Sep 09, 2007
jsrock516
  • 5911 Answers
SOURCE: whirlpool microwave model # MH6150XLQ
Yes, there is. If you go to searspartsdirect.com and type in your model number, you will find the fuse listed under the "Interior Parts" heading as item number 14 (part #815174). You can find appliance fuses much cheaper at the local hardware store. Just make sure it is the correct type and rating (refer to the fuse in the appliance for the information - these are usually a 120V 20A fuse). The reason I mention this site is because they provide excellent part drawings and provide part numbers. There should also be a wiring diagram located behind the control panel to assist you in troubleshooting. Please go to my profile and use the "Ask Me" feature if you require further assistance. I hope this helps you.
Posted on Jun 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Microwave Model R-1830: No power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open oven thermal cutout (TCO) on the top of the oven cavity / body or an open thermal fuse on or above the magnetron.
These should read closed (virtually zero) on a continuity check.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it went dead or when you plugged it in or opened or closed the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site but the best place to order Sharp parts is Tritronics.
Posted on Oct 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My sharp carousel II microwave doesn't seem to
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad?
We have the relevant service / repair manuals for this model and have uploaded it to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open these documents automatically, but you may need the free Adobe Reader
I would suspect the 20A ceramic line fuse or the magnetron temperature fuse.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
20A ceramic fuses are available at local appliance part stores or places like Wal-Mart and Lowe's.
Posted on Jun 04, 2009
SOURCE: NEFF MICROWAVE OVEN BLOWS 10A INTERNAL FUSE
We had the same problem, got Neff service engineer to come out after taking out insurance. He said the megatron cracks which is a large magnet and causes the fuse board to blow and needs to be replaced. This occurs through lack of ventilation on instalation. Total cost £370 may as well get a new one. Plus our insurance wouldn't pay the cost and cancelled the insurance policy.
Posted on Jun 08, 2009
My Neff microwave has lost all power. It tripped the main switch at my fuse box. I have re-set the switch but still no power. Any ideas. Is there a fuse in the microwave and if so where is it?
There are two or more fuses on microwaves, but when they cut the power feed it is for something, if you bridge them you will find that your oven doesn't work properly, it will make weird noises and produce a power low in your home. If you want to check it, the main fuse use to be inside a plasitc tube with two wires on it's edges, one conected to a big condensator, and another one to the inner circuit.
Feb 19, 2015 | Neff Microwave Ovens
Sanyo EM-SL20 Super Showerwave 900W Powergrill has stopped heating
see the informaton with carefully and use the common sense:
God bless you
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem.
Sep 09, 2012 | Microwave Ovens
Unit is showing no signs of power. Mains fuse has been checked and replaced.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 01, 2011 | Neff H7871N2GB Convection / Microwave Oven
We have lost all power to our neff microwave/convection dual purpose oven - no lights no action! help!!
first check that there is power to the unit,,,if there is,,its the unit thats faulty,,it could be an internal fuse poped
Nov 28, 2010 | Microwave Ovens
The internal 8a ceramic fuse has blown on my Sharp platinum collection 900w microwave oven, model R-957. fuse is marked F8AH 240V and is located on a small circuit board inside the rear of the oven. is...
Don't know if this a regular problem with this unit, but for this fuse to blow, there must be a problem further downstream. Maybe with the power supply or the Magnatron.
Sep 07, 2010 | Sharp R-1874 Convection/Microwave Oven
Ours magic chef 900W MCD990ARB completely stopped. We have it in our camper and everything on that end is fine. Checked the micro in a different outlet, still no go. Any suggestions?
Well if you are lucky it is an internal fuse. Open it up and look somewhere near where the cord comes into the unit. If it is not the fuse then I suggest you replace the whole thing.
I recently was attempting to repair one. The part cost $93, a new microwave costs that or less.
May 11, 2010 | Magic Chef MCD990W Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Neff h5642 doesn't start at all. No lights, no display. What should I check first?
safety fuse (internal) will have blown usually caused by faulty inverter short circuit if fuse changed and blows again this is what it will be costly repair if out of guarantee.
Apr 19, 2010 | Neff H5642 Convection / Microwave Oven
Mar 24, 2009 | Neff H5470 Microwave Oven
Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Dec 11, 2006 | Neff H7871N2GB Convection / Microwave Oven
Neff H5470 Microwave Oven Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
