Dryers Logo
Posted on May 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wirlpool Estate Gas Dryer that does not dry
The "estste" gas dryer lights and clothes are left in a damp tste. Using the propduc with jeans it takes several a trials, using both auto full dry and maximum time dry for jeans to be in a damp unwearble state. This unwanted feature happens with all dry attempts.
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
  • Posted on May 04, 2008
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563444
Points
4850
I think your temperature sensor is defective in the dryer section..
check it out
Dryer is not getting as hot as it should. Items that would normally take 45 min to dry are still damp after 130 min! Also, there seems to be a faint trace of natural gas odur left in the damp clothes. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
The sensor doesn't seem to work?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
DUET DRYER WON'T DRY CLOTHES ALL THE WAY THRU -
heatman101
Jun 01, 2010 • Dryers
My LG dlg2532 takes forever to dry clothes. When the drying cycle ends, the clothes are still quite damp. It's a gas dryer and the dryer seems to be getting gas since it does eventually dry the clothes...
How long are the vents? do they go for miles in your house?(sarcasm) Does the dryer have good ventilation? Check the vents again and make sure it is clear.
2answers
It take 4 cycle to v dry towels or jeans then
Remove all air restrictions and clean out the lint chute. I am supposing you have already done so. Since it does heat a little I am thinking the ignitor flame sensor and fuse are all good. So that leaves these operating coils.7942d84.jpg With a little age they get iffy. Feel the coils if one of them is very hot that is the bad one. In rare cases this flame detectoref9f9ec.jpg will work and then take fifty forevers to work again. The bi-metal gets brittle and takes longer than the norm to cool down and close for ignitor operation.
Lets review: The power comes from the closed control689f826.jpg and limit.fdc9a7a.jpg
the ignitor hogs all the juice and gets screaming hot till the flame detect opens and kills power to the ignitor. This frees up juice for those pesky inter-mittant coils to energize. Any of the above componets are wank and she don't dry right.ffc3f7f.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 • Dryers
1helpful
Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Top Dryers Experts
john h
