Question about Hitachi 43FDX01B TV
Replaced both IC's and the R will not move at all now. Used a DMM and checked all the resistors, I notice that the Hitachi repair kit for this set, and the service manual for this set list two different Ohm ratings for a few of the convergence circuit resistors. There is a 2.2Ohm, RK42 that reads 3ohm on my DMM, BUT, for comparison, I checked another 2.2Ohm resistor elsewhere and it read 3ohm on my DMM as well, so I do not suspect that resistors are faulty, but why are some of the values in the repair kit manual different (higher) than the ones listed in the service manual? Repair says the 2.2 should be 3.3OHM. Should I purchase resistors that match the ohm rating for repair kit?
  • justjackyl Aug 22, 2010
    Part 2:
    repair kit has STK-394 or 396-160, whereas I just replaced with the excat STK392-110. Also, now when I enter service mode, nothing will adjust, unlike before I replaced them, I could adjust the RGB, barely moving the R, but now none move, in manual convergence adjustment, the red line does not go the entire length of the screen as it did before. I did swap the connectors for red and blue, and blue was unable to be changed, and red could, of course this was tricking the circuit, but it's helped me pinpoint the problem to one IC. Any suggestions? I checked for solder splash, loose or missing connectors, made sure none of the joints for the IC's we're bridged and everything checks out.
MikeNJ1964
  • 398 Answers
SOURCE: Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Posted on Aug 29, 2007
  • 1694 Answers
SOURCE: HITACHI PROJECTION MODEL53FDXO1B CONVERGENCE PROBLEM
Replace both IC's with Hitachi upgrade STK394-160E PART #
CZ 01341....about 30.00 each....check resistors near IC's...
can be bad 2.2 2W, for example......................T.
Posted on Jan 03, 2008
  • 6 Answers
SOURCE: STK
All the info you need is contained in this link
http://www.digitalhome.ca/forum/showthread.php?t=21847
Posted on Feb 08, 2009
  • 42 Answers
SOURCE: convergence chips changed out now I have no picture
undo what you have done now also unplug convergence circuit and see if set comes on you may have solder two pins together are one to ground
Posted on Feb 22, 2009
SOURCE: what are the resistors you have to change when
Replaced the 2 IC chips and put the stk 150 chips in.
Posted on Oct 20, 2009
55" Hitachi colr Red has dropped to the bottom right
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 03, 2009 | Hitachi 50UX57B 50" Rear Projection...
AV-48WP30 - Is this a convergence board issue?
yes u r right that is the problem of convergence in your televisions.and it needs to be replaced to make it proper.
thanks.
Oct 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Red color distortion hitachi 46f500
Can't remember which this one uses but its right on the chips. Check your resistors too.
Apr 08, 2009 | Hitachi 46F510 46" Projection HDTV
Poor colour balance
  • Screen looks 3D
Mar 17, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi Television
  • Screen looks 3D
Feb 18, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Too much red!
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Oct 08, 2008 | Hitachi 53SDX20B 53" Rear Projection...
Hitachi 65xwx20b convergence
Your message says you "replaced stk392-150", did you replace both of the stk`s or just one of them??? One is for RGB vertical the other is for RGB horizontal, you should always replace both stk`s as a set, Hitachi recommends you use a "replacement kit"
part number X480306", this kit includes both stk`s with a new & supposedly improved set of stk`s as well as all resistors that are required for proper set-up, they strongly recommend you change all of the parts in their kit. The only other thing besides IC`s & resistors that could cause your problem is:
1) bad dcu output (you need a scope to check this)
2) you`ve lost either the +15 volt line or the -15 volt line to the IC`s, "Fxxx" chemical fuse open in power supply.
Dec 01, 2007 | Televison & Video
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Colors all messed up
The fact that you used the term "magic focus" tells me you have a Hitachi projection set. When the colors no longer line up on a Hitachi projection TV, it means that most likely one of the convergence output IC's has shorted out. Sometimes a shorted convergence output IC will burn up a low value resistor too. I have also seen a convergence IC crack loose from the board and burn up 3 low-value resistors. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The output IC's should be resoldered / replaced and the circuits checked and realigned by a qualified tech familiar with Hitachi projection sets.
Sep 09, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Hitachi 53FDX20B
If you have a color (red, green or blue) that is bowed inward from any side, then one of your convergence IC's has cracked loose or burned out. There is no way to fix that manually - the IC and possibly a resistor must be resoldered or replaced, and that should be handled by someone experienced in repairing and realigning convergence circuits.
May 06, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 43FDX01B TV Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
