Question about Vacuums
I have a Beaumark Tiny Turbo V600 hand held vacuum cleaner which needs an extension hose but I can't find one.
  • 126 Answers
SOURCE: Hoover F7425-900 How to attach hand held cleaner
There is a round door at the top/front of the clear duct on the hood of the unit. You insert the hose there and then connect the small solution hose to a valve that is located on the right side (if you are facing the machine) of the machine, just ahead of the rear wheel.
Posted on Mar 30, 2008
  • 97 Answers
SOURCE: We have a Bissell Revolution Lift-Off Turbo 3760-1
these belts need to be changed every 6 months regardless of the way they look.
Posted on Jul 20, 2009
SmartAlec
  • 171 Answers
SOURCE: Very little suction in hose no tears in hose
Hi there, SmartAlec from NelsonVacuums.com.au . I have fixed hundreds of Dyson DC07 vacuum cleaners over the last few years and i would say there are 2 possible causes for the loss of suction.
1st is that the filter looks clean but is actually worn anyway. The way to tell is remove the washable filter from your vacuum cleaner. Take out the foam insert this seems to last longer that the other part. Hold up the plastic cage to the light and look at the white part (well it used to be white anyway) you should be able to see light through it. If you cant see through it you need to replace it. Here is a link to that filter for purchase . To verify this is the problem just run the vacuum without the filter in you should see an improvement - note do not actually **** up material the filter is there for a good reason.
2nd problem is that you have a blockage in your radix assembly. If you take off the whole dirt bin and feel the suction on the upright part where the chamber joins the vacuum (basically bypassing the radix) if there is good suction here you will either need to replace the cyclone top or dismantle and clean it. (it is very difficult to clean as it doesn't completely dissassemble)
Hope this helps - If you want more help send me a message
HAPPY VACUUMING ! :)
Posted on Aug 26, 2009
  • 41 Answers
SOURCE: The cleaning solution stopped coming out of the
If you can check where the vacuum hose where it is connected their might have dirt in the opening to the rotating brush,or it is glogged,clean with a wire and it will be ok
Posted on Oct 10, 2009
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson dc27 (not ball version) extension wand will
    Sorry to hear you're having difficulties with your DC27. If the wand is jammed, it's likely that the hose was twisted when you replaced the wand on the cleaner the last time you used it. It's easy to rectify:
    • Pull the wand up as far as it will go
    • With the rear of the cleaner facing you, follow the hose down to where it attaches at the base of the machine
    • Grip the section of loose hose and pull it away from the cleaner
    • Holding the loose section of hose out of the way, pull the hose release tab
    • With the base of the hose detached from the cleaner, allow the hose to straighten itself out
    • Reattach hose to cleaner
    You should find following these steps untwists the hose, allowing the wand to move up and down without restriction. However, if you need further assistance, please get in touch with us free so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Aug 01, 2011
    Orange spring will no longer hold cleaner in upright position.
    You may need a replacement spring just a guess so here's the list of replacement parts with prices best of luck! Spare Parts AUTOMATIC X4 SEBO Vacuums Online Store
    Jan 07, 2016 | Sebo Automatic X4 Extra Upright Vacuum...
    How do i buy parts for my hand held dyson vacumn
    Call the Company on the box, or should be on Vacuum, where the serial/model numbers are located.
    Aug 27, 2014 | Dyson Dc-17 Hand Held Turbo Brush, Part...
    Dyson dc24
    Check hose for clog
    Jan 02, 2014 | Vacuums
    Can't get my bissel steam cleaner to sucktion
    Check on board switch for tools only or vacuum, is switched to vacuum, as majority of vacuum suction power is diverted to hose/ hand held devices. See if vacuum hose has suction as well? The unit may be clogged with carpet fibresas well and the unit may have to be taken apart and cleaned thoroughly.
    Apr 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
    I have a Bissell ProHeat Turbo 2x Carpet cleaner.
    Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
    Bissell Proheat Upright Wet/Dry Vacuum Problems
    heatman101
    tiutiu
    Jan 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
    MY hoover steam vac hand held hose cleaner leaks profusely
    try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
    Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
    Floor attachment does not suction, no clog in the hose, hand held works when dettached from floor attachment
    Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
    May 07, 2009 | Vacuums
    Mar 21, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
    Vacuums Logo
    97 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
