Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Machine goes into an f1 failure mode, why? - Whirlpool Cabrio WTW6600SBT Top Load Washer
    President:
  • 1,382 Answers
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Posted on Aug 22, 2010
Unfortuately not a solution, although the Whirlpool Representative said that F than 50 flashing as a code is saying the motor will not engage.
Posted on Sep 23, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    on Apr 24, 2015 | Kitchen Ranges
    Tip
    F5 - E0 Door Switch
    Two digit codes:
    Regards.
    on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    F1 error relay circuit failure
    Hi This is the Alarm system watchdog circuit :
    The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
    If the beep continues after pressing cancel check the main control ERC board.
    Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
    F1 error code comes and goes does not happen all of the time, what is it and what needs to be fixed
    Hi...The error indicates a failure of the main CCU that operates the machine.
    You can find tech notes for diagnostic under the top of the machine
    Apr 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
    F1 (F60-68)
    Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    See Accessing & Removing the Electronic Assemblies.
    F1 flashing on the display indicates a primary control failure.
    "F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
    The link below lists Cabrio failre codes.
    http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
    Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does F1 mean?
    Hi
    Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jul 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does f1 mean and can it be fixed?
    F1 means Primary Control Failure.F then 1 flashes when there is a
    primary control failure.Replace the machine control assembly and
    see accessing and removing the Electronic Assemblies.
    Apr 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Dacor oven beeps and shows F1 code
    -F1- Alarm “System Watchdog Circuit”
    The system will detect a failure in the internal watchdog element relay circuits and will activate a
    cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
    function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
    the ERC is picking up a command to supply heat without receiving an input from the membrane. The
    watch dog circuit is designed to prevent this.
    If the beep continues after pressing cancel check the main control (ERC)
    Dacor
    Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
    When trying to pre-heat my oven, It won't until serveral attempts later (maybe 10 ). Then, after baking and stopping the oven, I get an F1 error! What's going on?
    F1 is listed as "Element Relay circuit Failure".
    There will be a current switching relay to the oven - which is faulty - hence why you get the error when it realises it's not working.
    This should be replaced to solve future problems.
    For your reference, the fault codes are -
    F0 Touch pad stuck in depressed position
    F1 Element relay circuit failure
    F2 Oven temp exceeded the clean runaway temp (self clean) -or- runaway temp (cooking modes)
    F3 Short circu!t in oven temp sensor
    F4 Open circuit in oven temp sensor
    F5 - N/A
    F6 Failure in the EEPROM check comparison (only time of day and timer will operate)
    F7 Failure of Sef-C1ean auto door latch circuit.
    F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking Self-Clean mode.
    If this resolves the issue, Please rate accordingly. Thank you.
    Jun 26, 2008 | Dacor Kitchen Ranges
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    201 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
