Question about RTO Sole F80 Treadmill
Error code of ls1 on sole f80 treadmill - RTO Sole F80 Treadmill
  • 20 Answers
John what are you talking about. All that's gonna do is give a LS error is you disconnect the motor.
Posted on Aug 16, 2014
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: SOLE F80 TREADMILL STARTS TO RUN THEN STOPS.
Sound like a speed sensor adjustment here the steps for this procedure:
1. Unplug unit then remove the plastic motor cover. There are either 4 or 5 screws holding the cover in place depending on the model.
2. Locate the speed sensor between the front roller pulley and the frame of the treadmill. It is a small plastic piece approx 1 1/4” long and 1/4” in diameter with a black wire coming from the back of it leading to the electronic board in the motor compartment .
3. Locate the magnets mounted in the face of the pulley. (approx. 3/8” in diameter) 4. The end of the sensor should be positioned approximately 1/8” from the magnet at the closest point.
5. Follow the wire from the sensor to the control board. Make sure the connection is pressed firmly down on the board.
Posted on Apr 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Posted on Mar 13, 2010
  • 156 Answers
SOURCE: We can't get our F80
Is the motor running? Even if the light comes on doesn't mean the motor is turning on.
Posted on Sep 19, 2010
  • 33 Answers
SOURCE: New F80 treadmill. Belt doesn't move after hitting
hi, check the 12pin communication cable
Posted on Oct 11, 2011
Sole F-85 treadmill E-5 error
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Sep 27, 2016 | RTO Sole F80 Treadmill
Shows LS1low speed treadmill stops working what is the solution
hi check the video
Sole F80 LS1 Error
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
Nov 16, 2015 | Sole Fitness F63 Treadmill
My fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
Oct 01, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
May 15, 2012 | RTO Sole F80 Treadmill
Belt wont start on a brand new Sole F80. Motor
Mar 12, 2010 | RTO Sole F80 Treadmill
RTO Sole F80 Treadmill Logo
5,046 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
