Question about GE GSS22JFMWW Side by Side Refrigerator
The hole where ice comes throuh door freezing is freesing up
The ice depenser is freezing up and the hole it gones through. i can take the depenser out clear all the ice build up off of it and it will work for about a week before it freezes up again. got any i ideas
  • edward357 Jul 30, 2008
    GSS25WGMA side by side has problems. Hole through which ice dispenses doesn't close completely and ices up. The flap has already been replaced. Also, icemaker doesn't shut off when full so ice overflows. Previously the ice maker leaked and ruined the floors. This produce completely sucks.
  • 74 Answers
Flap closes under spring pressure and may not be closing fully causing ice/snow build up . Bend the spring to adjust the tension and lubricate with a little vaseline
Posted on Aug 28, 2008
When I press the ice depenser lever nothing happens no noise at all and no ice in glass.
Your dispenser is probably broke. You should get someone to come repair it for you. I have had something similar happen to me before.
Nov 27, 2014 | Refrigerators
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; . Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, or unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Oct 27, 2009 | Refrigerators
Ice depensing door will not close on LG model LSC27926ST
It is probably frozen in place. The old ice tray bend and spils in the Ice Bin and eventually leaks out that door. Have you changed the ice tray with the update? This might fix your problem. Do you know if the door has illumination for the buttons? Mine doesn't and I think there should be somethng cause it is hard to read the buttons in the dark.
Sep 07, 2009 | LG LSC26905TT Side by Side Refrigerator
Water keeps freezing
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. This seems to happen on certain models. The door insulaton may have detereated. Some parts places have a heater to add on to prevent this. I have heard of taping additional insulation inside the door to prevent this.
Aug 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cream comes out fine at first the mashine doesn't cut off then it seems that the ice cream freeses in the cylinder to the point its to hard to come out
Use slightly warm ingredients or leave the freezer bowl out of the freezer for a few minutes before beginning - this will help if the rim around bowl freezes so fast that it stops the paddle from moving. When working optimally, I found that 3 different Cuisinart ice cream maker models will produce the best ice cream at around 14 to 20 minutes - no more than that. But it varies by your exact model #.
Jun 01, 2009 | Cuisinart DCC-2000
Ice tray freezing
the water inlet valve may not be closing properly due to dirt or some mechanical problem in it. u can clean and try
Mar 10, 2009 | Kenmore 50522 / 50524 Side by Side...
My ice depenser is freezing up and the hole the ice goes through in the door
BET IT'S A GE? YOUR SOLENOID THAT OPENS AND CLOSES THE ICE FLAP HAS RUSTED AND WILL NOT CLOSE ALL THE WAY LETTING AIR IN AND FREEZING THE CHUTE,CALL LOCAL REPAIRMAN.THANKS-MIKE
May 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool ice dispenser not working
RECHECK THE CONNECTIONS AT THE UPPER DOOR HINGE WHERE THE ELECTRICAL WAS DISCONNECTED. MAKE SURE ALL THE PINS ARE STAYING IN THE PLUG WHEN YOU CONNECT THEM TOGETHER.
ALSO, BE SURE THE ICE BIN IS PROPERLY INSTALLED.
Apr 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice despenser door not opening
I had this problem. There is a piece of ice jammed in there that is blocking the door. try pouring some warm water into the hole from the inside and naking sure the path is clear.
Apr 14, 2007 | LG LSC26905TT Side by Side Refrigerator
GE GSS22JFMWW Side by Side Refrigerator Logo
116 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
